SBC cylinderhead chambers - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2013, 09:18 AM
Slammedsi's Avatar
I was wondering how much gm changed the sizes of the chambers on factory heads, mainly the later model (76-86) 350 sbc. Just out of curiosity did they range from 58cc to 80cc and up? Or did most come with a single size?
Old 05-26-2013, 10:26 AM
bondo's Avatar
Ayuh,... I think you'll find the 58cc heads are 305 heads, 'n the largest chambers I can think of are the 76cc heads....
The Following User Says Thank You to bondo For This Useful Post:
Slammedsi (05-26-2013)
Old 05-26-2013, 11:51 AM
Slammedsi's Avatar
Besides the double hump heads and the vortecs is there a good casting number to look for when looking for stockers. The reason I ask is, I've got a old friend that has acquried close to 50 sets of heads over his lifetime. When I dig into them I would like to know what to look for.
Old 05-26-2013, 12:13 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
The stock castings is the main reason for the aftermarket heads.Yrs ago we found even with the experience of a porter like Joe Mondello how much we where limited.....................
The Following User Says Thank You to 1Gary For This Useful Post:
Old 05-26-2013, 02:00 PM
Slammedsi's Avatar
Oh I'm not consirned with performance figures. But sence I am getting a set for free I would like to have a good set other then a smogger set if there is one in his lot of heads.I already own a set of aluminum heads for a sbc. I'm just looking to add to my own personal collection of parts.
Old 05-26-2013, 02:27 PM
1Gary's Avatar
The 58cc Vett aluminum heads with the dished pistons that come with them
Old 05-26-2013, 03:25 PM
techinspector1's Avatar
Wiki Edits: 326
Go through the list of Chevy heads here......
Stan Weiss' - Cylinder Head Flow Data at 28 Inches of Water -- DFW / FLW Flow Files for use with Engine Simulation Software
The Following User Says Thank You to techinspector1 For This Useful Post:
Old 05-26-2013, 05:27 PM
Slammedsi's Avatar
I only wish he had a set to give me! Then I doubt they would be free.
Originally Posted by techinspector1 View Post
Thanks for the link.
Old 05-27-2013, 07:48 AM
It appears no one wants to answer this one...
350/400 heads are mostly 76, as stated. There are good ones and bad ones. The "heavy casting" 624s and 882s are okay, deficient exhaust port. The light castings of those numbers will crack if you breath on them with a fever. The large chamber heads are plentiful, but certain castings are desirable in racing classes where no modifications are allowed. 441 is considered the "best" large chamber head. It's precluded by rule in some circle track classes BECAUSE it's so good (compared to other stock castings). 336, 487(X), 991 and 993 are among the more popular, with good exhaust ports.
There are a handful of small-chamber 350 heads, too. 041 is the most common, and a pretty good head. It rendered virtually all the 327 stuff obsolete.
There's still a decent "market" for the iron heads among the circle track crowd. Restoration guys are also looking for "certain" castings to make things correct. Date codes are important to them.
FWIW
Jim
The Following User Says Thank You to Mr. P-Body For This Useful Post:
Slammedsi (05-27-2013)
Old 05-27-2013, 02:27 PM
Slammedsi's Avatar
FWIW
Jim
I left with two sets of assembled 882 heads and a set of 305 heads with the smaller chambers. Not sure of casting numbers as there still in the back of the truck and attached to a complete 305 haha. Not bad for some free parts huh?
SBC Cylinderhead oiling issues 4lug39 Engine 8 09-18-2012 07:50 PM
CC-ing chambers with clay ganymede Engine 8 05-31-2012 11:11 PM
Cylinderhead Recomendations fore hyd/flat Scandinavian Engine 27 01-04-2012 02:59 AM
200. dome sbc pistons with heart shaped chambers? 355guy Engine 4 12-10-2010 11:55 AM
Welding combustion chambers Augusto Engine 8 03-14-2007 09:08 AM
