SBC Dart Pro-1 215cc Heads - which valves? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2010, 11:15 AM
v8hed's Avatar
AK427
I recently purchased a pair of these heads (bare) and have seen conflicting advice re. valve length. The supplier I purchased the heads from state +.100" required, yet looking at a Dart spec sheet for the Platinum heads (which these are NOT), they specify +.100" valves are required only if 1.550" springs are used. I'll be using Comp 986-16 springs (1.430"), so I'm now thinking that stock length valves are needed.
Can someone clarify please?
Thanks.
Old 08-21-2010, 11:36 AM
ericnova72's Avatar
More for Less Racer
This is a tough call, spring is listed as 1.800" installed height and puts you right at the point it could go either way, depending on spring seat or cup thickness, retainer style and valve lock ledge location. Standard length may leave you without enough room to get the spring height spec and then searching out higher retainers and plus height locks, which can sometimes lead to rocker arm interference with the retainer. A +.100" valve would give you room to juggle the other way, shimming under the spring seat or cup and/or using minus height valve locks to dial it in.
I myself would go with the +.100, and IIRC all the Dart Pro heads with larger than 1.250" stock diameter springs come assembled with +.100 valves,... at least all the Pro-1's and Iron Eagles I have touched are that way. Sportsman II's also.
Old 08-21-2010, 11:42 AM
cool rockin daddy's Avatar
Have you ever been to the Dart website. They have a page devoted to answering tech questions if you don't want to call them. They are very good at answering quickly. Don't you think it would be best to call Dart about this? I know that is what I would do.
Old 08-21-2010, 11:55 AM
v8hed's Avatar
AK427
Great info, thanks. I'll stick with the +.100... what you say definitely makes sense; it's easier to shim than to be stuck with insufficient installed height to start with.
How great is David Vizard's book on SBC heads, anyway? BinderDriver Engine 12 04-22-2008 05:55 PM
Got some questions regarding intake, pistons, etc. Malibu73 Engine 36 05-03-2007 11:30 PM
head ache. sbc heads excaliberprime Engine 7 03-07-2007 06:03 PM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
BB Chevy Heads MERLIN vs PRO TOPLINE ss crazy Engine 3 03-26-2003 07:38 PM
