sbc deck clearance
I ran into the same problem with my BBC. Mine were .017-.021 on both sides. the bummer was I had the short block put together. I ended up disassembling the block and having the machine shop deck it to square it up. Ended up at .005 in the hole. Since I am building a 496 cid I also had the the three center mains drilled and installed Program 4 bolt main caps and align bored.
Yes this sounds about right. I had this same problem on my first shortblock build up recently. After doing investigation here is what I found: If you want perfection you have to pay for perfection (line hone block (or aftermarket block), deck the block, expensive aftermarket crank, quality aftermarket rods, quality pistons, quality measuring tools).
Here are some details... There will be differences in deck height from each side of the block. GM made the blocks to be "close enough". If you want to make them exact, then you are going to have to get the block line honed. This is where they rebore the main bearing journals and caps for the crank. This puts the center of the crank exactly at the center of the block. If you do this, you also need to get oversized main bearings to accommodate for the removed material and you have to get a different sized timing gear set to accommodate as well. Other factors that can contribute to this are: -crank shaft throws are not indexed at exactly 90º. This can be a problem with brand new factory cranks (not really that common though), or from reground cranks, or from cheap Chinese cranks (Eagle and Scat). Sometimes if they are not offset too much, you can get an offset regrind to bring them back on center. -rods can stretch. -rod bolts can stretch -rod caps get elongated -cheap pistons that do not have an precise compression height (wrist pin center to piston crown). As an alternative to the line bore you can have the machine shop measure to the existing center of the crank to the deck. They will do this on all four corners (cylinder #1,2,7,8) and then deck the block so that all four corners are even. Generally it is noted that factory block corners are higher than the middle. Also when you measure, try not to let the dial indicator go past its highest position. I usually try to make a slow pass, note where the high point is, then rotate back to the high point. Once at TDC I also use a straight edge and slip feeler gauges underneath to find the clearance. Also be sure to measure parallel to the crank (this is parallel to the wrist pin) and will eliminate any measurement errors due to the piston rocking in the bore. |
You're probably not crazy! It only feels that way when you see this stuff. Bogie |
Bogie |
If you are racing then fix it. Otherwise slap it together and call it good.
sbc deck clearance
Prostcelica, I don't have any idea of the money you have spent so far on your rebuild. I was in the same situation as you with my block but not quite as far off. I kept thinking of what's going to happen if I put it together like this. As was suggested you could use 2 different size head gaskets. One would have to be a steel shim gasket to = .053 and the other needs to be .032 thick to = .053 thickness. If the crank center-line is off how is that going to affect how long your engine last. Like I said I had the block decked, the block drilled for (3) new 4 bolt main caps and align bored and honed. I also had him hone my block again while he had it. Then had it dipped for cleaning after the machine work was done. The machine shop charged me $500 which I thought was a really good deal. I would call and check the price to deck it and align bore it for peace of mind.
Thanks guys. Much appreciated. I only have $800 dollars invested in the Short block as I bought it from a freind of a freind. Aparently it was good to go Bored 30 over new flat tops, bearings and ARP rod bolts. I guess this is a classic case of you get what you pay for
. I spoke to the machine shop today and he said my best bet is to right down all the deck heights for each bore, remove the internals and bring it to him. He said he will parallel deck it to get both sides close to the same. 185$ + tax. Im going to do it. I thought of using a steel shim on one side and a thicker mls on the other but it seems kind of hokey.
This will be my first time dissasembling a bottom end so I just had a few questions. Ive been doing some reading and it seems if I take everything apart and keep it all orginized and make sure it all goes back together the same way I should be good. I actually only have 1 question. Being that this motor has just been rebuilt can i re-use the carnk and rod bearings?? or are they no good to re-use after the crank and rods have been tourqed down??
Yes you can re-use the bearings, just keep them in order. When you put it back together plastagauge it for a peice of mind.
I might be i little worried about leaving the cam bearings in. Talk to the guy doing the machine work get his opinion. I had my block decked and line honed and it ran me 170 to deck it 160 to line hone it.
| Stock deck clearance of a 454. | 1fast62 | Engine | 4 | 02-14-2011 11:00 PM |
| What is the standard deck clearance on a SBC? | Silver Surfer | Hotrodding Basics | 4 | 01-08-2011 05:44 AM |
| Question about measuring deck clearance | v8hed | Engine | 3 | 06-15-2008 04:37 PM |
| Piston to deck clearance, and compression | BourgD | Engine | 24 | 05-13-2008 06:36 AM |
| Deck Clearance-SBC 350 Mr. Goodwrench Motor? | acr | Engine | 7 | 04-20-2005 04:11 PM |
