SBC Deck hieght - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2006, 05:58 AM
Redman Racing
SBC Deck hieght
I was wondering what the stock deck height for the above mentioned motor is? I see allot of different piston companies that sell flattop or what ever type piston that use the same head cc but quote different compression ratios. Can someone please shed some light on this. I know about Zero decking a block I just need some insight on how these companies get the compression ratios with stock blocks.
So lest say you take a basic 350 Chevy block - lets say an 70's 010 block. Now if you were to zero deck the block approximately how much material would be taking off the deck? Is this a proceeder that you would need the piston placed in the block first and than measure the difference between the flat of the piston to the top of the head deck? Are there differences is years for example a 60's block compared to a 80's block?
I looked though the archives and did not find the answers I was looking for???
Thanks in advance
Josh
Old 06-21-2006, 04:21 PM
King of my Man-cave.
Specified deck height of the SBC is 9.025". This can vary, I have seen some 400s that are closer to 9.035". It's good to measure what your block is to start with, that way you can calculate the CR accurately. Cutting the block to 9.00" will make zero deck if the rods are the correct length and the pistons have the OEM specified compression distance. It is a good idea to mock up your assembly to determine exactly what you have and to determine what to mill off the deck to get your desired quench.
tom
Old 06-21-2006, 11:57 PM
Different piston makers use different deck height figures, as well as different thicknesses of head gaskets when they calculate CR. KB Pistons uses a total piston-to-head (quench) clearance of .040", and Federal-Mogul (SpeedPro, Sterling, Sealed Power) uses .025" deck height & .038" head gasket for a total of .063".
Some cheaper pistons can have a compression height that's reduced from standard by up to .020", and when you add that to the higher quench clearance, you get lots of empty space between the piston & the head, therefore lower CR.
Redman Racing
Thanks Tom and Jim,
I guess not every block is the same. Thanks for the info.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 10:43 AM
$4,557.99 for SBC 400 Parts/Machine Work DTL504 Engine 35 04-03-2006 06:36 PM
Verify deck height on sbc? jtybt Engine 3 02-25-2006 10:52 PM
Critique my SBC 400 Combo DTL504 Engine 24 11-30-2003 06:37 PM
