Remove the tube, and take the piece of 5/16" (or whatever's closest) hard line, put a flare on one end, and drop it into the same place the tube goes. The flare will keep it from falling through, then reinstall the tube. IIRC, the bottom tube is 6"-7" long- I think I have one in the shop- I'll check it and add an edit. |
No need to drop the pan if you can determine that the lower tube is missing. The lower tube drops into the dipstick tube hole in the block before you drive the upper tube into place(press fit). Just pull the upper tube to add it, it is just a perfectly straight piece of tube and will slide right into place.
Cobalt tree'd me LOL |
I have a deep sump oil pan, does it need to be specific to a 383? I have a 383.
I should also have a tube that goes into the oil pan? I am so confused. Sorry i stumbled accross this thread, and I have to replace the dipstick cause the old one broke off when the guy i bought the motor from was moving it. |
All of these engines I have sent out for machine work, I have always removed the lower dipstick guide to keep from bending them. It then gets placed in the gasket set, unless I am installing the oil pan.
I have only found a few blocks that did not have one, and 5/16" steel line works good. |
Some of the newer blocks use a dip stick tube with the extension made into it. |
thanks a bunch! hows things by the way? i've been meaning to come by but i have insanely busy! |
If you can swing by around 7:30 in the morning, I'll have that blown 383 Corvette here. If not, it will be at the El Cajon car show tomorrow afternoon/evening. I pulled some spark plugs last week, just to see how it was burning. They looked a perfect dark shade of gray. |
I would think that one of those would also fit a block that originally had a 2-piece tube like y2k600f4's or pitbull's. In any event, if need be, I have a couple older blocks here- I can try one of the long, 1-piece tubes to see how it fits into the block. It will need to be a good press fit, like they are in the blocks they came from. So that might be an alternative to fashioning a bottom tube, since the 1-piece tube already has the correct bends to it to clear the bottom end. And the 1-piece tubes are long on the bottom- more so than most 2-piece tubes, as I remember them being. I can't find any bottom tubes I mentioned having earlier. They're here somewhere but MIA at the moment.
| SBC Stroker Oil Pan Problem?? | 89SDime | Engine | 2 | 02-12-2007 03:07 PM |
| SBC oil pan/ gasket differences | curtis73 | Engine | 6 | 02-11-2007 12:38 PM |
| One piece sbc oil pan gasket? | jtybt | Engine | 1 | 04-26-2006 05:33 AM |
| Oil pan - kicked out sump good? | dh79 | Engine | 4 | 06-15-2005 01:32 PM |
| 7qt Oil Pan & Pickup SBC Small Block Chevy | Mustangsaly | Engine | 6 | 06-12-2005 07:52 PM |
