SBC Dip Stick Sleeve Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2006, 09:19 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
My "made in China" dip stick sleeve has broken off at the block with about 1/8" sticking out. It is refusing my attempts at removal. Any suggestions on an extraction method that do not include dropping the pan? That may be the last resort.
Old 09-25-2006, 09:47 AM
nitro_baller4692's Avatar
floppers forever
try to collapse the side of the tube to get some needle nose vise grips on it and twist it out.
Old 09-25-2006, 10:22 AM
poncho62's Avatar
Wiki Edits: 5
or...an easy out..............
Old 09-25-2006, 11:19 AM
Following up, I had a similar problem and tried the easy out, but it didn't work (I had used Permatex #1 to make sure the sleeve stayed in). I added a little heat (just until the permatex began to smoke a tiny bit) and the easy worked just fine then!
Pat
Old 09-26-2006, 06:35 PM
Thread a bolt into it, then tap upward under the bolt head with an open-end wrench that barely fits over the shaft. Or tap the wrench with a hammer or a piece of pipe.
Dip Stick Reading 70bird Engine 10 06-08-2006 11:21 PM
69 428 Pontiac dip stick dgcantrellsr Engine 3 05-27-2006 12:22 PM
driverside dip stick REZ_DEVIL Engine 3 10-22-2005 05:27 PM
Tranny dip stick tube gilby246 Transmission - Rearend 2 05-11-2005 01:07 PM
oil spits out dip stick and breather dosch13@aol.com Engine 5 12-11-2003 05:27 PM
