sbc dist. problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2012, 04:45 PM
sbc dist. problem
I just got a performance hei, really cheap, 38 plus shipping. its new not rebuilt. I droped it in, and it sits about 1/8 above the manifold. I thought it needed to go in the oil pump, but that was not the case. It,s in the pump, when it,s not in the pump it sitsmore than 3/8 high. it drops in the pump and does not bottom aginst the manifold it sits on the center drive shaft. If I tighten it it will be in a bind on the shaft. the shaft seems to long, is this possible ? What can I do? What can I check? Is the cheap part suffering from poor qualty controll? Is it junk? I am pissed. Or am I missing somthing? HELP! As always THANKS for your help.
Old 12-31-2012, 05:53 PM
Richiehd's Avatar
JS-70
Something not right, Check the length against a stock one or the one you took out. I have had it where you needed a shim or 2 but 1/8th inch seems a bit much. I always check the depth WITHOUT the gasket and make sure there is a little room, so as not to bind the pump, then install gasket. I had one of those Chineses performance distrbuters in my Speed Skiff, it didnt last long.
I think those shims are available at Summit or Jegs
Old 12-31-2012, 07:57 PM
RWENUTS's Avatar
Sometimes the tang that fits into the oil pump slot is a hair to big. Grind it or file a bit off. Go slow, test fit several times if needed.
Old 01-01-2013, 01:43 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If there's a plastic collar on the bottom of the pump drive shaft like used stock, sometimes the collar will get pulled up out of position when the distributor is removed. It can be pushed back into place w/a long screwdriver, etc. if this has happened. It's better to use a drive shaft that has a steel collar.
SBC Dist. will not line up? will it ever end? chucksrt Engine 28 05-01-2012 04:38 PM
Weird dist. problem,please help SBCFREAK Electrical 3 12-05-2008 08:54 AM
What do i need to get going sbc dist. Chevy Hi-Po Electrical 1 02-19-2006 09:53 PM
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 03:31 PM
problem with dist. rotor onecoomofo Engine 3 05-22-2004 07:15 PM
