Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC distributor question
Old 03-12-2004, 09:06 AM
Steve-0321's Avatar
Steve-0321 Steve-0321 is offline
Ok, I have an 88 Trans Am....305 TPI....i broke the little magnetic pick up thing under the rotor when i tried to take the rotor off because it was rusted on the distributor shaft. Anyways, my question is can i get a HEI distributor from a junkyard out of another sbc like a 350 and have it work, or does it have to be out of another 305, and will I be able to use the HEI distributor with the connections that are for the stock non-hei distributor or will i also have to pull the wiring for the HEI? any commments or suggestions will once again be greatly appreciated. THANKS
