Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Engine build advice
Old 01-06-2013, 07:12 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by newboldspeed View Post
That's making things better to understand. Thanks techinspector1
I do have 76cc cast heads 1.72/1.50 valves. But then......
will the valves be large enough for a blown motor. Mmmmm.
whats you thoughts?
I'm of the opinion that most everyone misinterprets what is necessary to make a blower motor work. For a street motor with up to 6 lbs of boost, you don't need a double-throwdown camshaft and sewer-pipe heads. The blower will compensate for a plethora of errors and still make good power (25%-40% increase over stock) at street rpm's, on cast iron exhaust manifolds and stock head gaskets. Just as in the remainder of life, there are varying degrees of success, based on the combination of parts used.
