Sbc Engine mounts the same? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2005, 05:37 PM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
I busted my motor mount the other day, Just got around to pulling it out today. Sucker was split totally in half at the rubber part....
Anyway, when i go down to get another one, do i just ask for a regular v8 motor mount for my car. 65 elcamino 350....I know they will have 327 mounts, they're the same for the 350 right? I see them at autozone part #2267 for 327 elky for 8 bux. havent checked kragen yet.
I know ya guys can answer this one, Thanks.
Abe.
*edit- added pics of broken mount. rubber broke off the metal part...
ID:	6815   Click image for larger version
ID:	6816   Click image for larger version
Old 09-11-2005, 05:56 PM
docvette's Avatar
Wiki Edits: 12
Mounts
Doc here,
Here is the mounts for a 65 El camino body...to small block (65 was only offered with 327 as the largest engine that year.)
http://www.partsamerica.com/ProductD...ype=27&ptset=A
Here is a set for a 1975 Elcamino body with 350 ...
Except for the plate on the later year 350 they look the same...
These are transdapt mounts and you actually get them through Parts america, or Kragens for about $80.00
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-11-2005, 06:05 PM
well, as usual you rule Doc.
But, YIKES!!! thats expensive....
I can spare 30 or 40 bucks but 8- wow..
I guess im gonna hope that the 327 mounts fit, i dont see why not except if they have different mounting locations than a 350 i dunno...hope not. Im not too certain thats why i asked, but i had thought the sbcs had same mounting points...its already been setup for the 327 or 350.
Old 09-11-2005, 06:14 PM
docvette's Avatar
Wiki Edits: 12
mount
Doc here
I do't se an differeance betwen the two except the price and the Plate ...
you'll note the one for the 327 is listed as "Small Block" which should include the 350..
Doc..
Innovations
Old 09-11-2005, 06:55 PM
I found the oem part # on the rubber of the mount, punched it in kragens search and it came up.... http://www.partsamerica.com/ProductD...artnumber=2142 8.99 Whew.. pic is exactly the same...
Again thanks doc for the help
*edit 2 n half hrs later,...... Heres a update.
I went to kragen, got 2 mounts 8.99 a piece (installed 1, saving the other for when i break another one)...they worked, got them installed..
Also bought a chrome air cleaner on sale for 17 bux and a new temp gauge for 14.99 (i broke mine pulling the headers off to get to the mount)
Went out for a cruise and everythings all good, the mount solved my problem, no more tranny or engine moving
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
350 sbc upgrade... Engine will not start FenderGitars Engine 10 10-08-2010 04:26 PM
Engine and transmission mounts cucumber1949 Hotrodding Basics 1 08-07-2005 09:15 PM
Engine Mounts DoubleVision Engine 1 11-17-2003 07:54 PM
sbc engine ID codes tm454 Engine 3 07-22-2003 05:18 PM
