She slowed down on ya huh.How about posting the wt,60' and 330' times.Where are you leaving at??. Shift points??.
Im guessing the horse power at 400 ish.You did not say what tires you have on the car.If it bogged Im guessing slicks.With a 4 speed in that heavy car,expect to break lots of items.
Im not a fan of RPM heads for horse power,I do not like the 700 holley or the 800.For your car I would use a 750 double pumper. Love the strip dominator though an air gap might work better with your car being so heavy.11.5:1 is not very street friendly. If that is a small crower cam,it works gooood. your launch gear is 9.5:1 and considering the weight and relatively small engine its not going to jump with tall slicks.If you insist on a manual,consider a 5 speed with a lower first gear or a 5 speed with more rear gear. The O/drive will make it better as a street car if you have to drive a distance. 107 MPH should get you into the mid/high 12s. After you fix the bog you might find another MPH. If you have front engine mounts you better have a chain or cable for torque control of the engine,especially with slicks. did you weigh the car? |
Thanks for the reply back...She tips the scales a little heavy, just a tad over 3500 with me in it. I was suprised I thought it would be alot more. I'm actually away from the house now and can't remember the 60' times. They weren't the best with a bog lol. Generally shift around 66/6700 with the rev limiter set around 6800 just for back up. Didn't have much time to play aroudn at the track with it this year so I'm excited to get it back together and expierement this spring!
I do realize there are much better heads out there then the RPM's. I'm sure if I switch to a set of AFR's or Dart's I'd pick up alot better, but I got a great deal on the heads and didn't have the funds at the time to go for more. My strip dominator is my pride and joy, I love that thing! Thanks! I did just pick up an 830 Holley so I'm gunna give that a wirl and just work with what I got. 11.5:1 has been fine on the street for me. Never have an issue pinging, only when it's super hot out. I always run 93 in it and then when I go to the track or big car shows I'll run 100 through it. I got 28x11.5x15 M/T ET Drags and I tried 28x10.5.15 MT Drag Radials but thats what busted the driveshaft this past summer. Slicks will help on the launch, DR's would prob. be better off with an auto?? I'd love to get a 5 speed for it one day. That would be sweet! Once I get the 4.11's in, I'm gunna switch back to my M20 Muncie with a shorter 1st gear than my M21 which will help on the launch. Either way, poor times or not I'm having a blast!! LOL |
2.20 X 4.11=9 VS 3.73 X 2.54=9.4.the close ratio and 4.11s will be worse for launch and Muncies in stock condition do not last long in heavy cars.
10:1 launch gears are the base line.you could use 11:1 in your car |
2.54 X 4.11=10.4 and if you upgrade to a 2.78 first gear then
2.78X4.11=11.4.that would make her jump Ive used the 830 annular holley and I liked it after I got it tuned correctly.you should see power to 7k with that carb and intake |
Ahhh, I see now. Makes sense, didn't understand how that worked before, thanks for the clarification. If only I still had my 4.88s back in it! Like I said, she's just a street car, so I want to keep it rather "street friendly." I've now come to realization that theres a street car...then a race car lol. Hard to have both. With the power I'm putting down, I don't think I have a problem with my muncie. If I switch to big block and make near upper 500hp ++TQ then maybe she would give out. I'm not to worried about it for the amount of racing I do. Would love to have a Richmond one day. Maybe if I get into more racing.
I got the 830 from a good friend for free! Can't beat that! So come spring and all go well, if i'm running the M20, on estimation/guess what do you think the car should run if I get her to launch decent off the line? I have no problem keepin the right foot planted when shifting either LOL Thanks for your advice as well. |
You ain't gonna wanna hear this, but I would stop fumbling around with those stickshifts and get a Turbo350 in that sucker ASAP.
It will save your drivetrain, AND you will turn better ET's. 28" rear tire with 4:11 gears, you could start with a 4,000 stall converter and see how the combination feels. Definitely run a 750 double-pumper carb. You do anything with the rear-end setup at all? ( ladders, trac-bar, etc? ) Put that pig on a diet! See if you can get some weight out of it.
| The Following User Says Thank You to 632Mantis For This Useful Post: | ||
mbroske67 (12-17-2012) | ||
HAHAAH thanks 632 Mantis! Love the truck, I got a 67 C10...Now that is an overweight slob! She deffinetly needs the diet. I do hate to hear that, but I'm aware my ET would pick up. I'm happy runnin anywhere around 13 possibly 12s for what it is..
I got a TH350 layin around, maybe takin a day dustin it off and putting it in the car would be neat to try. (Not much of a project, same tail shaft as my muncie). I want to keep it a street car and just play around at some of the Nostalgia Events, so i'm gunna keep my 4 speeds in it for now. I got this 12 bolt now all buttoned up with new Moser Axles and a good drivetrain components. The rear is a 12 bolt and I got traction bars on it. I got about 180lbs of damn seats in the thing. It's got old Monte Carlo swivle buckets. I took the seats out one day and about broke my back. Them things are heavy! LOL Thanks for the advice! |
| SBC 350 Engine Advice needed | Clayton A | Engine | 24 | 11-04-2012 12:24 AM |
| SBC Racing camshaft and lifter help please! | ragincajun19 | Engine | 4 | 02-25-2011 12:45 PM |
| need a racing engine ? | che_javss | Hotrodding Basics | 8 | 12-16-2009 01:23 PM |
| Anybody with drag racing advice? | Blazin72 | Hotrodders' Lounge | 28 | 08-15-2009 03:56 PM |
| Bench racing SBC talk... | JonRunaas | Engine | 6 | 12-04-2007 12:04 PM |
