Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc and engine stand
Old 11-07-2012, 06:03 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Wiki Edits: 326
3/8 is the major diameter of the bolt. 16 is the threads per inch. I suspect that you mean you use bigger NUTS as washers, not bigger bolts and that's OK too.
For instance, you could use a 1/2-13 nut as a thick washer for a 3/8-16 bolt.
