Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC exterior makeover - Help needed
Old 01-07-2013, 10:13 PM
bigdog7373's Avatar
bigdog7373 bigdog7373 is offline
Of course it's fast
Originally Posted by wasral View Post
whats involved in a gear drive set? will that drive everything? or again only the alt and water pump
Gear drive is your timing. Instead of a chain you put gears and it will whine.
For your accessories do like i said before and get the 7 groove pullies and run the poly belts. It's a cheap way to get away from the v-belts.
