sbc factory hyd. roller motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2008, 08:16 AM
When changing heads on a hyd. roller short block for example TBI heads to dart iron eagle or TBI to Vortec does pushrod length change? I do realize that Vortec use self align rockers as opposed to guide plates on dart heads I,m stumped on pushrod mysteries
Old 01-12-2008, 01:18 PM
GMC boogie's Avatar
Should not be an issue but,allways check for proper geometry.
Old 01-12-2008, 05:17 PM
i agree. its easy to do with an adjustable push rod length checker, makes it 100% easier and is accurate.
Old 01-12-2008, 05:40 PM
Too many variables. Cam specs, deck height, valve length, cylinder head construction, cylinder head milling, angle milling, not to mention many times different rocker arms require different length push rods as do lifters with different pushrod cup height locations. Always verify correct pushrod length.
Hyd. Roller lifters on Solid roller cam danrace1 Engine 6 01-28-2010 06:21 PM
SBC roller cam selection 307malibu Engine 5 12-15-2007 10:53 AM
Front Motor Plate for a SBC Stonebrier 2 Hotrodders' Lounge 1 10-30-2007 03:54 PM
Proper Tightening Sequence Roller Rockers SBC 1FST4DR Engine 12 07-16-2006 07:18 PM
SBC Nascar Motor sb72elcamino350 Engine 7 03-01-2004 01:59 PM
