Sbc firing order changes? - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 02-05-2012, 11:44 PM
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
I happen to be doing some reading recently on (ferrari, datsun L6 motors etc) v12s and L6s and angle of crankshafts etc. I came across some info on why v12s and L6 motors are "naturally balanced". Apparently aside from crankshaft angles uses of flat plane crankshafts, one of the biggest factors was the firing order of the engines and how that then affects the throw of each cylinder balance the other piston throws (in basic terms).
So - that being said, theoretically, what firing order would a sbc need to have to be balance like these motors?
Blight~
on a side note
http://speedtalk.com/forum/viewtopic.php?f=1&t=130
Quick reply to this message
Old 02-06-2012, 12:01 AM
Why would this be moved to general rodding tech? This is particular about engines- where this originally was...
Old 02-06-2012, 08:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My understanding is the firing order of a 90 V8 compromise between breathing and torsional stress. There are three that are most often used:
1-8-4-3-6-5-7-2 (Mopar, Chevy, Ford pre-~'70)
1-8-7-3-6-5-4-2 ("4/7 swap")
1-8-7-2-6-5-4-3 (Ford ~'70-up, Chev LS)
Regardless of which of these firing orders are used, there will be two cylinders on each bank firing consecutively and once the two cylinders will be adjacent cylinders that fire consecutively.
I hope Old Bogie or Techinspector1 notices this thread and fills in the many blanks/details.
Old 02-06-2012, 10:14 AM
What would be the most balance set of pulses then? Most as in the closest to being balanced.
v8s
1-8-4-3-6-5-7-21988 Chrysler Fifth Avenue, Chevrolet Small-Block engine
1-8-7-2-6-5-4-3GM LS engine, Toyota UZ engine
1-3-7-2-6-5-4-8Porsche 928, Ford Modular engine, 5.0 HO
1-5-4-8-7-2-6-3 BMW S65
1-8-7-3-6-5-4-2Nissan VK engine
1-5-4-2-6-3-7-8 Ford Windsor engine
1-5-6-3-4-2-7-8 Cadillac V8 engine 368, 425, 472, 500 only
1-5-3-7-4-8-2-6 Ferrari V8's, (all are flat-plane crank)
1-2-7-8-4-5-6-3Holden V8
1-2-7-3-4-5-6-8 Cadillac Northstar Engine
v12s
1-7-5-11-3-9-6-12-2-8-4-10 2001 Ferrari 456M GT V12
1-7-4-10-2-8-6-12-3-9-5-11 1997 Lamborghini Diablo VT
Old 02-06-2012, 10:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The way the SBC was originally designed has served that engine well for a long time and that's what all the aftermarket and production cranks are designed around. Since there's basically only the 4/7 swap to change to (unless you were starting w/a blank sheet or were going to use a 180 degree crank or split rod journals like even/semi-even fire V6 engines use), I'd leave it be.
Old 02-06-2012, 10:43 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
v8s
v12s
When comparing the firing orders, be sure you take the way the cylinders are numbered into consideration.
As an example the Ford "1-5-4-2-6-3-7-8" is (when looked at using Chevy cylinder numbering) is the same as Chevy: 1-8-4-3-6-5-7-2.
The Northstar, IIRC, has #1 on the left side looking at the "front" of the engine, driver side transversly.
Old 02-06-2012, 01:36 PM
Blight~
on a side note
Has nothing to do with firing order, the issue is of secondary balance which is having a cylinder's parts in motion off setting the actions of another. In this case an inline 6 or a 60, 120,180 degree V12 have such a situation because of block and crankshaft configuration.
A 90 degree V8 always has a little secondary vib, there's no way around it by juggling firing orders or anything else short of a counter balance shaft.
The I6, V12 and V8 have primary balance which is the rotational masses in balance. The secondary balance the is motion of the reciprocating parts. Their motions are not linear with crankshaft degrees. Each piston with the rod small ends and some amount of shank have different rates of acceleration as the crankshaft turns and the reciprocating parts move up and down rather than round and round as the crank and big end of the rod do. For secondary balance there needs to be a combination of two cylinders worth of rods and pistons that are doing exactly the same acceleration but in reverse directions of motion to each other.
By "acceleration" I'm talking the different speeds the piston and upper rod travel at even when the engine itself is held to a constant RPM. This has nothing to do with speeding or slowing the crankshaft.
It's all in high school trigonometry class. Think how much more fun it would be with engines for examples instead of dry memorization of trig functions and the doing of inane problems. The SAE keeps bugging me to become a math mentor, maybe I should. That would be one bizarre math class.
Bogie
Old 02-06-2012, 02:07 PM
If you do it, please do it online so that folks NOT in the great NorthWest can share in the fun.
Pat
Old 02-06-2012, 09:08 PM
Pat
More detail than I know just yet.
Using your response to expose the guys to the Buick Nailhead firing order. This is the same cylinder counting as the Chev but a way different firing order of 1-2-7-8-4-5-6-3.
OK I'm locking up and going home.
Bogie
Old 02-06-2012, 09:13 PM
what is your opinion on 4-7 swaps etc?
Old 02-07-2012, 11:02 AM
1971BB427's Avatar
The 4-7 swap is what some racers in the 60's changed to in an effort to smooth up the engine and get a litle higher rpm's. It involves having a cam ground to this configuration, or buying one. (they are available)
The 4-7 swap is in my opinion a lot of work and money for very small gains, and not worth the time and money.
Closed Thread
firing order 88chevy Engine 10 01-06-2017 12:35 PM
64 Merc cyclinder order/firing order 64merc Engine 1 07-11-2007 09:17 AM
Firing Order 67 Hugger Engine 2 06-30-2005 07:26 AM
Firing order raidmagic Hotrodding Basics 3 11-02-2004 07:53 AM
Firing Order? TonyMac Engine 7 07-11-2003 11:06 PM
