sbc first start up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2012, 08:29 AM
sbc first start up
So I have this newly rebuilt sbc350. Getting ready to fire for the first time. Added the fluids last night. Kind of had a bear of a time getting the distributor to drop in and have it point at cylinder #1. Finally got it! I cant seem to tell if it is at TDC or not. No way I can get a wrench on the cam to turn by hand. Simply not enough room. Heck I can't even see the harmonic balancer to get an idea of were the mark is. If I take off the first spark plug and have someone turn the key with my finger over the hole will I be able to get the piston to TDC in cylinder one? Is there an easier way? Will I have to take that darn distributor off again after finding TDC? I did prime the pump before dropping the distributor down. Should I do it again today before firing? Lastly during the process of assembly the oil in the air conditioning compressor spilled out on the floor. I was told by Vintage Air that I should use PAG 120 and put in 7.2 ounces. I was only able to find PAG 100, how will I know that I have 7.2 ounces in it. Do I have to take off the compressor and dump out the oil and then refill? What a pain.
Old 10-04-2012, 10:35 AM
vinniekq2's Avatar
How long was the A/C system left open? was it sealed during repairs?Disconnect the power to the compressor.There is no way of measuring oil still in the system that I am aware of. receiver/drier may need to be replaced.when you take the car for evacuation and recharge explain what happened.
Old 10-04-2012, 10:46 AM
I had the caps off for about a week or so. Still have not made final hook ups to the dryer and such. I think it would be best to remove, empty and refill. Will there be any issue with PAG 100. i was told to use PAG 120, what is the difference?
Old 10-04-2012, 11:03 AM
SBC first start up
I would prime the oil system again before start up. Here is some info to read about installing a distributor. http://www.crankshaftcoalition.com/w..._a_distributor
sbc 350 will start run rough for a few seconds die and wont start fuel-junky Engine 11 01-08-2013 12:30 PM
SBC 400 still no start david-b Engine 17 11-30-2010 08:32 PM
Chevy SBC No Start david-b Engine 9 11-22-2010 03:39 PM
327 SBC where to start? 68Elcamino Hotrodding Basics 10 06-25-2010 09:38 PM
wireing to start a SBC BadA$$37 Electrical 3 08-24-2006 07:21 AM
