sbc flywheel question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2008, 01:14 PM
I just pulled the flywheel out of my 79 camaro because it needs a new clutch. the flywheel has lots of small cracks in it so Im gonna get a new one. I was looking at the flywheel and it has 2 holes drilled on one side near the edge, looks like for balancing. the guy who sold me the car said its a 350 that he had built in the 80s. is it possible that the flywheel is zero balanced with these holes in it? is there anyway I could tell or would I have to take it to a machine shop? thanks
Old 08-04-2008, 02:20 PM
Greg T's Avatar
www.krusinklassics.net
It shouldnt be a concern if it's a 350. A good quality name brand flywheel should be fine.
Old 08-04-2008, 02:31 PM
327NUT's Avatar
Just FYI...the small cracks are just "heat checks' as we call them. If they're not too bad you can have a good machine shop surface the f/w and re-use it. Now if you're going to be pulling a lot of high rpm's then a new SFI wheel would be a good Idea, along with a scatter shield.
Old 08-04-2008, 03:22 PM
Im not going to be pulling a lot of rpm so maybe Ill just take it to a machine shop and see what they think. so do you guys think its zero balanced even though it has those 2 holes drilled? its just 2 holes beside each other about 3/8 diameter and probably about 3/8 deep. thanks
Old 08-04-2008, 03:55 PM
As previously stated, the cracks are most likely heat checking, most likely from using the clutch as a torque converter, the part way in but not quite engaged makes for a lot of heat. A very good reason to develop a good heal toe technique for launching on hills.
For the holes, there are two possibilities. The 350 is internally balanced from the factory. The holes in the flywheel could be to get it to neutral balance by the factory, but the factory's idea of balanced is a wider band of goodness than the typical hot rod shop's idea of balanced. If this is a balance shop job it could be what was required to re-balance the wheel to their specs at neutral balance, this is pretty common. Or the entire rotating assembly could have been balanced and the flywheel and crank assembly are now a matched set. I really wouldn't expect this to be the case but it does happen. It's really not to difficult to see if it's neutral balanced, just support it in it's mechanical center to see if it sets horizontal to the earth, something like a bubble tire balancer will also work.
One last word about dynamic balance where the wheel would be spun. This method of balance is in 3 dimensional space. The wheel would not only be balanced in rotation, but also in plane at what's called the normal direction to rotation, which is to say thru the thickness of the wheel where an imbalance would cause it to want to wobble front to rear as well as spin off center.
Bogie
Old 08-04-2008, 05:52 PM
3rdmember
might want to check your parts store, they MAY have a "reconditioned" one (i think pioneer brand) for about the same money as a machine shop bill and you'll get a good ring gear too (if yours is bad)
just a thought...
FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel boneyard Buick Transmission - Rearend 1 07-20-2009 09:43 AM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 07:20 PM
Flywheel Question crusherdbuzz Transmission - Rearend 2 05-08-2006 11:00 PM
383 flywheel choice question undy Engine 7 09-26-2005 06:32 AM
New Flywheel Question 72chevy240z Engine 5 04-29-2004 02:25 PM
