-   -   SBC Flywheels (http://www.hotrodders.com/forum/sbc-flywheels-181621.html)
19nova69 07-25-2010 05:11 PM
SBC Flywheels
I need to get a new flywheel for my internally balanced 383. I see there are 2 available, a 153 tooth and a 168 tooth. I tried to look up what the difference between the 2 is, other than the obvious 15 teeth. I found the difference was between the staggered and inline bolt holes on the starter. Well, the block was a staggered and I drilled the 2nd hole inline so that I can use my Tilton starter. Which flywheel should I get??
ericnova72 07-25-2010 06:33 PM
Which diameter flywheel is the Tilton starter made for?? 153 tooth is 12-3/4", 168 is 14".
Some race starters have a double inline pattern in the aluminum mounting block and can be used with either flywheel depending on which set of holes is used, is your Tilton this way??
2old2fast 07-25-2010 07:18 PM
are you talking flywheel,[manual shift] or flexplate [auto] the majority of manual shift bellhousings won't fit over a 14" wheel,better to know which you're using . dave
19nova69 07-25-2010 08:10 PM
Sorry, flexplate..
Yes, I meant flexplate not flywheel. Sorry for the confusion..
