SBC Flywheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2010, 05:11 PM
SBC Flywheels
I need to get a new flywheel for my internally balanced 383. I see there are 2 available, a 153 tooth and a 168 tooth. I tried to look up what the difference between the 2 is, other than the obvious 15 teeth. I found the difference was between the staggered and inline bolt holes on the starter. Well, the block was a staggered and I drilled the 2nd hole inline so that I can use my Tilton starter. Which flywheel should I get??
Old 07-25-2010, 06:33 PM
ericnova72's Avatar
More for Less Racer
Which diameter flywheel is the Tilton starter made for?? 153 tooth is 12-3/4", 168 is 14".
Some race starters have a double inline pattern in the aluminum mounting block and can be used with either flywheel depending on which set of holes is used, is your Tilton this way??
Old 07-25-2010, 07:18 PM
are you talking flywheel,[manual shift] or flexplate [auto] the majority of manual shift bellhousings won't fit over a 14" wheel,better to know which you're using . dave
Old 07-25-2010, 08:10 PM
Sorry, flexplate..
Yes, I meant flexplate not flywheel. Sorry for the confusion..
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 08:29 PM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 06:56 PM
oil drain on SBC heads TerroRx7 Engine 7 03-17-2005 03:12 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 11:12 PM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 04:44 PM
