SBC front cover oil seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2012, 05:40 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Do I dare replace the oil seal on my SBC without taking the front cover off ? I don't want any leaks but I really don't want to mess with the oil pan either.
Would you try it ?
Thanks.
454 RATTLER
Old 12-20-2012, 05:44 PM
hcompton's Avatar
Old & Furious
Would you try it ?
Thanks.
454 RATTLER
No is the current seal spewing... If its a small seapage leave it alone. I have done it before it did not leak but i was lucky. I just loosen the pan and took off the cover. Oil pan leaked after that but it was minimal at first then got worse. The oil pan gasket was alot worse than a crappy seal since they usally dont get really bad for years. Oil pan was spewing in less than a years and it had to come out anyway.
Edit sorry ment to say i tried it both ways. Best to do it right the first time.
Old 12-20-2012, 05:45 PM
prostreet6t9's Avatar
Differential/Driveline
Piece of cake.. Just replace the seal and check Balancer for a Groove.
Old 12-20-2012, 05:55 PM
hcompton's Avatar
Old & Furious
Oh prostreet is right i was thinking about the timing cover gasket read that wrong. The right seal install tool will help you get it in if the radiator is in the way. Makes it easier to get it in straight. But with sbc its pretty easy.
Old 12-21-2012, 09:32 AM
NEVER SATISFIED !!
Thanks guys. I'll give it a try. I knew I could get good advice from you guys.
454 RATTLER
Ford 5.0 Timing Cover to Oil Pan Seal Problems Dorf02 Engine 2 06-05-2012 08:19 PM
Timing cover / oil pan seal jstuhl Engine 3 09-07-2010 07:29 AM
Using Permatex Right Stuff on timing cover oil pan seal eric32 Engine 2 07-29-2010 03:29 PM
Noob - Front cam cover oil leak on SBC 350 seattlematt Engine 23 07-10-2010 01:14 PM
SBC Oil Pan Front Seal (SOS) Canadian Charlie Engine 6 03-08-2006 03:37 PM
