-   -   SBC front crank seal install (http://www.hotrodders.com/forum/sbc-front-crank-seal-install-202721.html)
stroker00s10 07-26-2011 07:10 PM
Ok so what the the trick to installing a front crank seal in car ? I have balancer off seal out I have a steel sleeve same size as outer ring diameter but I can't get it started. I have a Spectre Chrome front cover and the seal that came installed in leaks live a **** old seal falls right in new one just dance around to my dismay any help appreciated.
DoubleVision 07-26-2011 07:27 PM
I dig up a piece of exhaust pipe or pcv pipe that fits around the crank and onto the seal, I lightly lube where the seal slides in. Place the piece of pipe up to it, use a hammer sideways on the pipe to apply a even force.
stroker00s10 07-26-2011 07:30 PM
like whack it with my 1lb ford tool hammer side ways ? I spent last hour till I gave up trying
engineczar 07-26-2011 08:47 PM
I have a tool I made out of PVC pipe and an aluminum disk. The PVC pipe is 2" in diameter and roughly 2" long. The aluminum disk is 2" in diameter and 1/2 thick with a 5/8 hole through the center. With the seal in place I use the balancer bolt to press the seal into the cover. It works well especially when there's no room to swing a hammer.
68NovaSS 07-27-2011 08:11 AM
I've always used that old brown gasket sealer for insurance and to slick things up, but it can be messy doing it on the vehicle. Plus it's probably way too old school these days.
