-   -   sbc front oil galley plugs. help please (http://www.hotrodders.com/forum/sbc-front-oil-galley-plugs-help-please-107682.html)
406 ss monte 01-27-2007 04:13 PM
i've got a question.
i took all the freeze plugs & the front & rear oil galley plugs out so it would get cleaned when i had it hot tanked.
i bought a freeze plug kit & it had all of the screw in type for the back & the center one in the front, but not the other two in the front. the one's that where in the kit where to small. the center one was a little smaller than the other two. this is a roller block & the plugs are a different size than the older small blocks. its a 305 roller block. where can i get them? what size are they? thanks
xntrik 01-27-2007 06:22 PM
Did you get the block acid dipped?
I've heard a little bit of rumor about "off shore" made plugs that seem to have a tendency to not stay in the block. Diameter? Too soft?
Try the machine shop that did your block. They should have the correct plugs available.
Henry Highrise 01-27-2007 06:27 PM
I get mine at NAPA auto parts...but any engine re-building shop should have them. If all else fails...get them from your Chevy dealer.
CNC BLOCKS NE 01-27-2007 10:04 PM
The Pioneer freeze plug kits should come with the proper freeze plugs you need.
406 ss monte 01-29-2007 05:28 PM
they are 9/16. not all freeze plug kits come with them.
