sbc front oil galley plugs. help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2007, 05:13 PM
406 ss monte's Avatar
eat a beaver, save a tree
i've got a question.
i took all the freeze plugs & the front & rear oil galley plugs out so it would get cleaned when i had it hot tanked.
i bought a freeze plug kit & it had all of the screw in type for the back & the center one in the front, but not the other two in the front. the one's that where in the kit where to small. the center one was a little smaller than the other two. this is a roller block & the plugs are a different size than the older small blocks. its a 305 roller block. where can i get them? what size are they? thanks
Old 01-27-2007, 07:22 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Did you get the block acid dipped?
I've heard a little bit of rumor about "off shore" made plugs that seem to have a tendency to not stay in the block. Diameter? Too soft?
Try the machine shop that did your block. They should have the correct plugs available.
Old 01-27-2007, 07:27 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I get mine at NAPA auto parts...but any engine re-building shop should have them. If all else fails...get them from your Chevy dealer.
Old 01-27-2007, 11:04 PM
The Pioneer freeze plug kits should come with the proper freeze plugs you need.
Old 01-29-2007, 06:28 PM
they are 9/16. not all freeze plug kits come with them.
excess oil fouling plugs gilby246 Engine 4 05-20-2006 10:44 AM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 07:07 PM
SBC Still fuel fouling plugs, Losing my mind! 67 Deuce 4 Me Engine 9 09-02-2005 09:56 PM
SBC Oil Pressure Problem....!!?? chevyelc81 Engine 8 07-25-2005 04:40 PM
Spark Plugs Are Light Grey/whits And Their Is Oil On The Threads 70SPORT Engine 1 05-26-2004 01:25 PM
