Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc harmonic balancer. need guidance.
Old 05-05-2013, 03:23 PM
ssmonty ssmonty is offline
Before you buy a crank bolt you had better make sure that crank actually has a tapped hole. The earlier engines didn't.
It may also make a difference as to whether or not you want to install a new dampner. Kind of tough on the thrust bearing if you have to beat the dampner on with a sledgehammer instead of buying or borrowing a tool(Autozone has loners) that threads into the crank hole specifically designed for the job(in case you didn't know).
ssmonty
