I think Chevrolet's original intent was that both marks be at the 12:00 position and verified with a straight-edge, but somebody whose kid hid the ruler just lined up the marks and timed it with #6.
The only difference if you line up the marks 12 and 6 are when you put the distributor in you will be 180 off.
Do not reuse the crank gear, remember that it spins twice as fast as the cam. It also has more pressure on the teeth do to surface area. I just press my crank gear on then put one cam bolt in and that will give enogh to get the other bolts in then just tighten it up and it pulls everything in place. |
| cam removal on 289 engine. | pi71 | Engine | 5 | 07-05-2007 04:37 PM |
| 305 cam removal???? | jajeff22 | Engine | 7 | 06-05-2005 05:16 PM |
| 1995 Dodge Avenger Cam gear removal... | zipfactor | Engine | 2 | 04-26-2004 11:27 PM |
