It would be a good idea to check over the push rods with a straightness checker and check out the rockers. The casting numbers pulled up as
458642.....75-84...350..........350 468642.....76-up...350/400 These heads were the common smogger heads of that era. likely have 1.94 1.50 valves, 76cc chambers. |
OK Thanks DV
I think they are a set from 1979 which would make them 350/400 heads. As far as the push rods go couldn't just roll them on a hard level surface and look for any abnormality in to rolling? Also on these heads are all the rockers 1.5? There was a web site that had all sorts of mixed rocker setups for these heads. Regards Mark |
Hey Double Vision.
I was browsing the web and a post came up on Hot Rodders from you saying that the 458642 heads were crack prone. Could you elaborate on this please. Regards Mark |
I know that my rockers move side to side too. And have that nice clickety-clack when it idles. Runs like stink...
![]() Never was able to find out what cam it has. The guy who replaced the racing cam (before I bought it) says that he got a stocker from Autozone back in 02 right before the tranny went...but I find it hard to believe that it's a hydraulic cam. Dart Iron Eagle 200cc heads...but it's been sitting for over a year so the cam is still new. A little movement is normal...Lot's of movement and you need to adjust. I too would see if your pushrods are straight, but it may just be a case of "wearing in" over the years and your rockers just need to be tightened. |
Could be collasped lifters, bad cam lobes, bent pushrods, just loose rockers arms or any combination of these. Best thing to do is start from the top and check the whole valvetrain just to be sure. The old school back yard mechanic way to check pushrods is to roll them on a piece of glass.
Well I went out tonight to check out the setup. I checked the pushrods and they are perfect, then I pulled the rockers and they to look good. So it's on to my first valve lash adjustment. It took me a couple times to get it close. I'm not sure it's perfect yet. But the rockers are fairly tight with very little side to side movement. I think I'll read up on doing valve lash again, and do it again tomorrow.
Thanks to all for the info. Regards Mark |
