Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC HEAD QUESTION: Need Help Picking A Head
Old 11-30-2007, 06:09 AM
GMC boogie's Avatar
GMC boogie GMC boogie is offline
Originally Posted by Mustangsaly
with a .525" lift roller cam turning 6200rpm I don't need screw in studs ?
everyone elses says I do.
thanks
Mustangsaly
It depends on which spring you are using. If using the LT4 springs from GM performance parts that come in the HOT cam kit,you will be fine with the factory press in studs. Are screw in studs stronger? absolutely
