SBC head stamp? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2008, 09:37 AM
SBC head stamp?
461 castings on a 327 pulled them off the other day and noticed a stamp number 3 on one of the flats where the valve cover gasket meets(both heads identical). I'm assuming it was from previous machine work but for the life of me can't remember what it indicates?
Old 04-26-2008, 10:12 AM
Holder350's Avatar
Auto Parts Professional
Most STOCK SBC heads dont have a machined valve cover sealing surface.
Most are a rounded ^ rough cast surface.
Old 04-26-2008, 10:19 AM
SBC heads
its not on the actual sealing area its a boss that was machined flat just inside of where the gasket rides if that makes sense
Old 04-26-2008, 10:23 AM
Holder350's Avatar
....AHHHHH I bet the heads were cut .030
Old 04-26-2008, 10:38 AM
if this is true and i think your right, there is more to this little 327 than meets the eye.
I did notice the pistons are .041 oversized and has a double roller timing chain. What else might I find? I don't plan on tearing down the bottom end. If
these heads have been milled are they worthy of rebuild or is the vortec the way to go?
I have read plenty on the arguement? as usual money is a limiting factor, I'm not looking for killer power just a respectable motor (for now)
Old 04-26-2008, 10:59 AM
Holder350's Avatar
When you mill a head to increase your CR.
so even tho it makes more power you have to run on high test.
IMO I would go with the vortech heads which will give you greater flow, more power and a lower compression ratio.
Thus having no problem with detonation and being able to run on low grade gas.
then if you want to mill those .030 and make even MORE power.
Keep in mind that this is saying that the heads you have now have something like a 64cc chamber.
SBC Head Identification Help Wadeamca Engine 8 09-07-2008 06:38 AM
How many cc's is a SBC 487 head? AGELE55 Engine 1 04-14-2008 11:34 AM
SBC HEAD QUESTION: Need Help Picking A Head Mustangsaly Engine 10 11-30-2007 02:48 PM
Increasing HP on my Blown SBC with Cylinder Head Replacement 1950bulletnose Engine 5 03-04-2004 12:00 PM
SBC head info please #458642 newchevyman Engine 4 07-16-2003 09:11 PM
