sbc head stud torque specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2012, 05:30 AM
Hi folks, I need a little info on torque specs on a 400 sbc
I'm switching to head studs after finding a couple of bolt hole to water jacket cracks- {The curse of the 400}
Do I use the same ft lbs as head bolts and do I use the same tightening pattern/ I'm also now going to an aluminum head if it makes a difference and will different style head gaskets require different torque requirements
Old 06-01-2012, 06:06 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
You will need to follow the recommendations of the stud manufacturer. The head studs should come with this information. As far as the pattern, again, that info should come with the heads you choose (if bought new).
ARP head stud torque in stock sbc block v8hed Engine 31 01-25-2011 10:29 PM
sbc oil pump stud torque specs streetrodderbn Engine 1 03-22-2010 06:34 PM
Stud torque specs for SBC heads? pittbull7934 Engine 9 08-08-2009 06:32 PM
head torque specs/angle torquing curtis73 Engine 7 05-02-2009 12:35 PM
rocker stud torque specs chevelle_502 Engine 3 03-20-2009 08:58 PM
