SBC head upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2005, 11:23 AM
SBC head upgrade
Well my 383 is at the machine shop now after a carb baseplate screw went through it.Currently I have 034 chevy Bowtie heads , lightly ported with 2.05/1.60 undercut valves.My cam is a ultradyne solid roller 249/259 @50 with .560 lift and .024 lash.9.7 compression and a Victor intake.I'm thinking now would be a great time to upgrade my heads.I know that AFR's and Canfields flow great numbers but I'd really like to stay with an iron head because my lash really does'nt change hot or cold.I'm looking at Dart Iron eagles with a 230 cc runners or Motown 220's.Anybody useing these.Engines going in a 70 Monte Carlo with a 3.90 gear and the converter flashes to 3500.Weekend toy , 70% street , 30% strip.Suggestions are appreciated.
Old 09-04-2005, 12:06 PM
Bumpstick's Avatar
Hammer and a torch
Pretty hard to beat the heads you have for your combo... The heads you mentioned would be better for more compression, cam and cubic inches... My opinion "your in the zone"
Old 09-04-2005, 12:20 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Cam is pretty stout. I agree with Bump on the heads. I think should be more like 200-210 max. I would prefer the Edelbrock AirGap (or even Performer RPM)intake, either will improve your midrange and overall average power curve significantly on the street. A good annular discharge carb probably would help that low and mid-range a lot too. You want that snappy throttle response don't you?
thanks
Old 09-04-2005, 01:04 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I would consider the Dart 215cc iron eagles at max, and have them sent to get cleaned up, not necessarly fully ported, but a little goes a long way from an untouched casting. As far as aluminum goes, if you have a good valvetrain, and a stud girtle, you really dont have to reset the valves too often. I think the AFR 210cc heads would be perfect for your setup. You would be looking at around $1400 a set, and they come fully CNC ported. If you spent $900 on a set of iron eagles, it will take more than $500 in porting to get them to the point where the AFR's would be.
Adam
Old 09-04-2005, 04:04 PM
Thanks for the input.Actually I had an Edelbrock RPM on it and it worked great.The only thing that bothered me is at the strip above 6500rpm the tach needle noticibealy slowed.My rpms drop to 5000 when I shift and from I've seen on a few tests , thats where the single plane starts to make more power than the RPM.Since it has plenty of lowend now I thought I'd give the Victor a whirl . Your right about not really having to lash.I don't have a stud girdle and there is very rarely any change.Well at least I'm in the ballpark.
Old 09-04-2005, 04:10 PM
Yep you were right-on with the AFR 210's.Read on another board that they were worth 6/10th on a Bowtie head 383 not unlike mine.
Old 09-04-2005, 04:36 PM
xntrik's Avatar
I guess I misunderstood. I didn't realize that you were building a pure drag car.
Old 09-04-2005, 04:39 PM
jesse01's Avatar
mini me
vroom vroom
J
sbc head HP jrmz28 Engine 0 07-14-2005 09:58 PM
Wicked SBC cylinder head Siggy_Freud Engine 4 01-06-2005 05:32 PM
Increasing HP on my Blown SBC with Cylinder Head Replacement 1950bulletnose Engine 5 03-04-2004 12:00 PM
SBC head info please #458642 newchevyman Engine 4 07-16-2003 09:11 PM
sbc cylender head questions 71vegagt Engine 4 06-26-2003 07:15 AM
