SBC headbolt removal question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2008, 03:28 PM
v8hed's Avatar
AK427
When removing headbolts, should I loosen in stages or is it acceptable to loosen each bolt all the way, providing the correct sequence is followed? I know that, when tightening, the bolts should be torqued in stages until the final torque value is attained, but I just wondered if the same should apply when loosening the bolts in order to lift the heads.
Thanks,
Ian.
Old 06-09-2008, 03:33 PM
DoubleVision's Avatar
It don`t matter how they come out.
Old 06-09-2008, 03:35 PM
v8hed's Avatar
AK427
Great, thanks. Does it even matter regarding the sequence, or can bolts be removed at random?
Old 06-09-2008, 04:03 PM
Wiki Edits: 31
I have always removed from the outside in, reverse sequence, but that's just me
Old 06-09-2008, 05:21 PM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project: Underway cont.
Wiki Edits: 3
With a motor that has unknown history (to me) I use a torque wrench for disassembly.
This method "may" indicate if their's a "potential" stretched bolt (low torque) or possible stripped/corroded threads that need inspection.
Excessively high torques may indicate other potential problems like warped heads/block that a previous owner has tried to fix by torqueing up a little more than recommended.
May be of use to you........Barry.
Old 06-09-2008, 05:54 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Ditto with DoubleVision, don't matter how.
We pull off very hot heads on a nitro motor without any problem, just pull the pushrods first.
Luv the smell of NITRO in the morning.
Old 06-09-2008, 06:03 PM
Thanks,
Ian.
I always take 'em out in reverse order of tightening them for the same reason, avoiding warping the head from the inside to outside. That's to say the tightening sequence is intended to push the stresses from the center to the ends. This prevents the center from being pinched by the ends which will cause it to buckle upwards. Cast iron doesn't like this and for the Chevy head, or any other, where the exhaust valves are adjacent to each other, this will put the point of maximum stress in the place where the casting is most prone to crack. Now just pulling bolts out of a cold engine may not make all that much difference, but why temp Murphy's laws, or in your case Lucas'.
Bogie
Old 06-09-2008, 06:12 PM
v8hed's Avatar
AK427
Thanks guys. Think I'll remove the bolts in reverse sequence to tightening, just to be safe. However, I won't bother undoing the bolts in 3-stages; I'll just loosen each bolt fully. On re-assembly, of course, I'll abide by the 3-stage torquing sequence.
Cheers,
Ian.
90s SBC Power Steering Pump pulley Removal Help Mustangsaly Engine 12 10-08-2006 06:00 PM
turbo sbc question. Super Chevy Engine 3 06-08-2004 04:57 PM
305 SBC question Aces0vr8s Engine 19 05-28-2004 08:18 PM
QUESTION: Where can I get a 350 SBC bare block? 78SilverShark Engine 13 10-04-2003 11:53 PM
SBC Cooling bypass line question HotRodF100 Engine 2 06-15-2002 06:50 PM
