SBC Headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2013, 12:33 PM
SBC Headers
Hey guys. I am considering building a set of full length headers. The reason I will have to build them and not just buy a set is because of space. The motor has shortys with 1.5" primary's now. The motor is in a celica street strip car. I have 2 questions really 1. Do you guys feel that this will be worth the trouble? 2. What size primary's should I go with?, what length, collector size etc?
SBC 355
10:1
Edelbrock E street heads (cleaned up)
Comp XE274 solid roller
RPM air gap
650 double pumper (might go 750)
The Following User Says Thank You to prostcelica For This Useful Post:
Gus's 40 (09-16-2013)
Old 09-15-2013, 04:22 PM
techinspector1's Avatar
Wiki Edits: 326
BBBZZZZZZTTT, wrong answer. Never, ever, let any component of the vehicle get in the way of constructing a good set of equal-length, long-tube headers. Frame in the way? Make a notch or build a "U" in the frame for the pipe(s) to go through. Steering in the way? Wrap around it. Inner fender panels in the way? Sling 'em over the fence.
I'm very sorry to hear that. You have my condolences.
SBC 355
10:1
RPM air gap
1. Yes. Read through this website, then talk with them on the phone before you pull the trigger.
Save 20% by buying Header Kits.* Kits available for over 100 engines and cylinder heads.
2. Minimum 3/8" thick header flange, 1/2" would be better in my opinion, 1 5/8" primaries X roughly 30" in length. 2 1/2" collector diameter. Make the collector 12" long to begin with. Using white spray paint, paint the collectors. Mount the headers on the car without the remainder of the exhaust system attached. Make a few full-power passes. The white paint will be burned on the front part of the collector. Where the burning stops is where you want to cut the collector and attach the step-down for the exhaust pipe(s). Fabricate either an H pipe or an X pipe before the mufflers. Run both pipes out to the rear bumper. Terminating the pipes under the car is "Ricky Racer".
3. E-Street heads will not support roller cam springs. Here's the disclaimer on the Edelbrock website.....
"Technical Notes: Use with Hydraulic Flat Tappet Camshafts .550" max lift. (NOT Compatible with Hydraulic Roller Camshafts) Recommended spark plugs are Champion RC12YC or equivalent 14mm x 3/4" reach with flat gasket seat. Requires hardened pushrods. Not legal for sale or use on pollution controlled motor vehicles."
4. Standard 7101 RPM is fine. Air Gap is a bunch of crap in my opinion. Just another way to wow you into buying new parts.
5. You do not need an XE cam in a street runner. Ease up on the ramps with a smoother grind. Once you have some experience, you'll appreciate the longevity of a milder grind as compared to the fosdick 10 hp you gain with an XE grind at the expense of fraggin' components.
Old 09-15-2013, 04:43 PM
Ok. Thanks for the advice on the headers tech. As for the heads. The valve train has been replaced with comp springs, retainers, locks, etc. that match the cam
Old 09-15-2013, 04:57 PM
Wiki Edits: 326
Be very careful here. There may not be enough meat under the spring seat to support a stronger spring. Talk with the Edelbrock engineers.
Old 09-15-2013, 05:09 PM
Thanks for your concern tech. It is much appreciated. I spoke with a tech a Edelbrock before I purchased the heads. He informed me that they are the same castings they use for there RPM heads just with different springs an less CNC work.
Old 09-15-2013, 08:49 PM
vinniekq2's Avatar
I would use 1 3/4 inch primary tubes and try to get 3 feet of pipe before 3 inch collectors and use red paint to mark the collectors for length
Old 09-15-2013, 09:05 PM
Thx Vin I was thinking of stepping up to 1 3/4 but wasn't sure. I don't mind loosing a little down low if it means I can pick up a 10th or 2.
Old 09-15-2013, 09:17 PM
vinniekq2's Avatar
1 3/4 tubes especially long tubes wont lose any torque at all.What Richard was saying with 1 5/8 and only 30 inch primaries: better low end with high velocity smaller tubes,but short so that the top end does not suffer,and he probably figured how much room your car has.
The 1 3/4 tubes I said are 6 inches longer and that too will give great low/mid range, and you are using a roller cam so dont hold back. Your car is light and I doubt it takes very long to get past idle to the sweet spot 3-6500. use a long collector and cut shorter after burning the paint off
red paint ;just messing with you guys
Old 09-16-2013, 07:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If this is a street/strip deal, go w/the 1-5/8" primaries. Strip only (or mainly) can benefit from the larger tubes (no need for anything bigger than 1-3/4" in any event), but w/no more cam than that, and w/o full-zoot heads, I'd still recommend 1-5/8", plus they're easier to work with. If you're up to it, a set of stepped tube primaries could be a good compromise.
Old 09-16-2013, 10:02 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
In terms of building headers,a Tig weld would be sweet,Gas Mig ant bad,Flex core Mig getting worst,stick weld,stick with your shorties and don't build headers at all.
Old 09-16-2013, 03:31 PM
Originally Posted by F-BIRD'88 View Post
If you are using a typical street rod center dump shorty header now you might want to
look at using a common 63 to 80 corvette SBC header and modifying it as required.
Or maybe a header for a RX7 V8 swap, may be close and only need a bit of custom re-fabrication.
That's a good idea. Ill check that out.
Old 09-16-2013, 03:46 PM
You also have the option of using shorty headers and fooling the engine into thinking it has a long tube header by
building a 2 in to 1 big exhaust pipe with a Y collector/Scavenger.
Burns Stainless (collector parts)
Flowmaster Y250350 Y collector 2.50" in to 3.50"
Just another way to skin the cat when you don't got a lot of room.
What is the performance of the car now? are you putting the power you got now, to the ground?
Or spinning the tires?
What is the performance gain you are looking for with new headers?
I am not familiar with that chassis so I can't visualize what you are up against.
One thing if you are building your own custom headers/exhaut system is you can take advantage of much better
joint - flange attachment sealing systems than a typical hot rod header has.
y
The car goes pretty good know but Ido have a huge traction issue. I will be putting a softer spring in the back ( don't know what's in there know but they are stiff). I also have a geomitry issue in the front. When the front end comes up the tires toe in pretty bad. I've come to figure that the length and plain of the inner tie rod is causing the issue. Plan is to narrow the rack to get the tie rod the same length as the control arm and use a bump steer kit to get it on the same plane. As I quick fix I just limited the travel but am getting zero weight transfer. The car ran a 12.1 / 115 mph with horrible 2.2 60ft.
As far as a performance gain I just want to get as much out of the motor as I can. I just got this thing together and have done nothing to tune or play with it. My plan is long tube headers, 750 carb, AFR gauge and the suspension issues. Any suggestions here would be much appreciated.
I'd like to get into the 10's (I know I'm along way off). Maybe a small shot in the future but not 100% sure if that's a good idea as it is a stick car.
Old 09-16-2013, 08:24 PM
I have a set of MT drag radials 295/55/15. Some guys say they suck and I have heard other guys say they work great. My first trip to the track my best 60 ft time was 1.77 but that was when the suspension wasn't limited and making impossible to keep my foot in it much past the 60 ft mark. That was also with the super stiff spring in it. The second trip to the track with the suspension limited all I did was spin.
Yes, @ WOT with the suspension extended it is all over the track.
The car weighs 2880 with me in it full of fuel
When I built the motor I was just building a street car....... After my first trip to the track I think I got the bug.
Old 09-16-2013, 10:39 PM
vinniekq2's Avatar
fbird,his little tube headers are costing him probably 4/10s
Old 09-16-2013, 10:55 PM
Does the rear end squat down on launch and what happens when torque is applied to the driveline when the car is stationary.? Does the rear suspension lift or squat? (rear suspension geometry)
The drag radials are critical on inflation pressure and rear suspension setup.
They work well within a narrower window of chassis setup, compared to a bias ply drag slick or ET street tire.
The "sweet spot" chassis setup window is smaller with the drag radials.
May have to find the right amount of front end lift to allow the car to get weight transfer and hook.
A chin spoiler to stop air from collecting under the car at high speed can really help pull the front end back down at high speed and
stabilize the high speed steering too.
what are some of your 1/8th mile ET and MPH compared to the 1/4 mile ET and MPH from various runs?
Yup, it's infectious and there is no cure.
The rear doesn't squat at all on launch it just kinda hops out off the hole.
7.70 / 96mph / 1.80 60 ft ( this pass was made with a ratchet strap limiting the suspension so the strap prob had some give to allow some weight transfer lol)
7.76 / 95mph / 1.77 60 ft
7.77 / 95 mph / 1.86 60ft
Help with SBC headers wickedtone83 Engine 3 02-17-2010 06:19 AM
93 SBC headers Eric64 Engine 2 08-05-2009 08:00 AM
SBC headers 66pontiac Engine 3 09-11-2005 04:34 PM
SBC Headers? riflegunbuilder Engine 1 08-03-2005 04:11 PM
LOOKING FOR SBC HEADERS chevyman17 Engine 5 04-17-2003 06:34 AM
