sbc heads
I am looking a good set of heads for our psv8 dirt car we are runing a 355 with a 420/420 lift cam 882 heads with 500 lift valve springs 1.94 intake and 1.500 exhaust. I just want to now if there is a better head. This is our head rule if that will help.
STOCK PRODUCTION CAST IRON HEAD NO MODIFICATION OF ANY KIND NO DOUBLE HUMP OR VORTEC HEADS NO ANGLE PLUG HEADS ON GM CARS. NO CLOSED CHAMBER HIGHPERFORMANCE HEADS SUCH AS 461,461X,041,186,OR 492. NO MINIMUM C.C ON HEADS NO ANGLE MILLING AND NO CUTTING INSIDE THE VALVE POCKET NO THREE ANGLE VALVE JOB . VALVE RULE IS MAX 1.94 INTAKE AND 1.5 EXHAUST. THANKS FOR ANY HELP. |
Thanks for the cast #s I looked them up I like the C.C 'S on the intake and exhaust ports much larger than the 882 heads . You wouldn't happen to now how much you can cut of these heads to get max compression because the 882 head can't be cut that much with out getting into the water jackets.
Thanks for the info we will be doing more home work when the season is over.
I am sure I will be asking for more info. THANKS. |
A #416 305 head with larger 1.94" in valves can be flat milled to 52cc.
Acid port them to increase port volume yet appear stock. These 305 heads do not have a "restricted port" like others do. Do a legal valve job but thin the seat width and make the seat as high as possible. Put a 30° back cut on all the valves. (it does not say you cannot) Clearance grind the chamber wall just enough to restore valve to chamber wall clearance with the larger valve and sand blast to hide it. You can also grind the 1.94 valves down to 1.90" so they fit the stock untouched chamber yet flow more than stock. Block the exhaust port egr passages. With some "hidden porting" and the larger valves these heads will outflow a 76cc head and the cr will be much higher. Install with a thin head gasket. Last edited by F-BIRD'88; 09-20-2010 at 09:45 AM. |
I think your biggest worry will be your 2 angle valve job... That can make more of a difference than what casting you start with. If you want compression I would run some 416's with the 1.94/1.5 valves and spend some time on the flow bench trying different valve seat dimensions.
Can you fill the exhaust crossovers? Are there any restrictions on the valves besides OD? Can you modify the chamber? |
| 400 sbc & heads | 67 coupe | Engine | 1 | 08-26-2008 09:40 PM |
| SBC heads and CR advice needed | v8hed | Engine | 8 | 06-18-2008 05:04 PM |
| SBC cylinder head bolts .. cast iron heads Vs Alum. heads | terror385 | Engine | 3 | 08-04-2006 08:34 PM |
| getting old iron heads to flow? (SBC) | KNanthrup | Engine | 9 | 12-21-2005 05:06 PM |
| sbc heads | sb72elcamino350 | Engine | 13 | 10-30-2003 08:53 PM |
