Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc heads
Thread: sbc heads
Old 03-03-2003, 01:24 AM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
Post
If I remember the 624 was an alternet for the 882 casting.There both known for cracking.
The 624s are better than the 305 heads in flow but are thin.If there not cracked and don't need allot of money use um.But if they need $300 worth of freshening can them and find a better set.
993s are a good 76cc head that can be found cheap.There supposed to be the most common 350 head and I don't think most people know there any good.
If you got flat top pistons you should be at 9:1 with a 76cc head just use the thin gaskets and maybe mill the head decks.
