SBC heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2005, 02:19 PM
NOlowrider's Avatar
US Navy-Retired
SBC heads
Hello everyone. I have a quick question about heads. I checked the numbers on my heads and they are 3947041. These are listed to have either 1.94/1.50 or 2.02/1.60 valve size. My question is, How can I tell which set I have? What is the overall opinion on these heads? I have a chance to get a set of camelback heads (not sure of the #'s yet) and would like to know if it is worth the trouble. What is the difference between the camelback and mine, if mine do infact have the 2.02? They are on a 327. Any help would be great.
Old 02-13-2005, 02:28 PM
lluciano77's Avatar
The camel hump heads are not worth the trouble at all. Vortec heads are the only stock heads I would ever consider using. Even then, I would still choose aftermarket.
I think the only difference in the heads may be whether or not they have accessory holes. The valve and combustion ccs may be different too so double check.
Old 03-26-2006, 10:51 PM
66burban's Avatar
You will have to take the heads off and measure the valve size to know which ones you have. I would not use the camelback heads unless you are in a racing class that requires a factory casting, they are old technology and do not have a big enough flow difference to make it worth switching. The stock vortec heads do flow much better, but I have recently heard many people having problems with them cracking. hope this helps, Coby
Old 03-27-2006, 11:39 AM
E.T. divided by $ spent= Speed
Funny how double humps were top of the heep for 30yrs then Vortecs come out and now they are junk.BS!!!!!!
If they only need minimal work ala: valve lap and springs to match your cam then go for it,they will out flow any large chamber 76cc GM head(your heads).They only become"not worth it"when they need a total over haul as Vortecs will then be cheaper to obtian,for an evan bigger HP gain.
Also remeber w/ vortecs you need those horrid looking valve covers,and a new intake,and if your cam is over .450 lift(most performance cams)you have to get new springs and mill down the valve guides.
Old 03-27-2006, 08:07 PM
automotive breath's Avatar
I do agree. I stopped using double humps because it was cheaper to buy a newer head. The design is outdated but that doesn’t mean they don't make power. I know plenty of people that still run them.
Old 03-27-2006, 08:38 PM
RippinRon's Avatar
Your 041 heads probably flow as well if not better than "camel humps" and they are guaranteed to have accessory holes.
Old 03-27-2006, 10:34 PM
the valve look like they are almost touching only looks as if a thumbnail will fit between the two. i love the double humps i wish i had a pair.
