Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC heads with weird valve seals
Old 05-04-2006, 07:40 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
The stock o rings will work fine if the stock oil sheild is there. You have to compress the spring then install the o'ring then the locks. If you put the o'rings on first they won't work.
