SBC heads with weird valve seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2006, 02:54 AM
New Member
hello all
I bought a 1986 GMC K15 which has a mexican reproduction 350 which was rebuild recently
after inspecting the heads I found no valve seals and they won't accept regular 350 valve seals
I've tried many types and I found a set of stock 454 Umbrella style seals that fits perfictly
but after mounting the springs I found that they touch the seals even when uncompressed
what should I do ?
Replace the springs with something bigger ( wider ) ? stock? aftermarket?
try other seals ?
thanks
Old 05-04-2006, 05:47 AM
302 Z28's Avatar
Regular 350 SBC valve seals are just "O" rings. The umbrella type seal you show usually requies the valve stem boss to be machined.
Vince
Old 05-04-2006, 03:39 PM
New Member
most 350s I have seen have both O-rings + umbrellas
this engine only have the O-rings but it is burning some oil
so is it enough to use the O-rings only ?
Old 05-04-2006, 03:56 PM
302 Z28's Avatar
GM has been doing it for 50+ years.
Vince
Old 05-04-2006, 06:13 PM
GoneNova/406's Avatar
positive stop viton seals is what most engine builders recommend,
summit has them and shows a picture of them.
Old 05-04-2006, 07:40 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
The stock o rings will work fine if the stock oil sheild is there. You have to compress the spring then install the o'ring then the locks. If you put the o'rings on first they won't work.
vortec heads on sbc 400 camino_man Engine 16 11-11-2005 01:33 AM
SBC twisted wedge heads?? 59vette Engine 4 09-12-2004 10:54 PM
bowtie heads for sbc Eddie Baker Engine 3 11-08-2003 11:02 PM
SBC 400 heads wcpalmex Engine 2 06-15-2003 08:56 PM
valve stem seals HQ Pete Engine 2 04-02-2002 12:04 AM
