sbc help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2013, 11:31 PM
sbc help?
I have been wanting to start a build and I have no clue on a engine to start with I have thought about building a chevy 302 but I have 400 sbc that needs to be overhauled and I have been thinking about it. I have heard of a 409 sbc but I have no clue about it. I know what heads and everything I want to use I just don't know about what block to use IM just wanting a hot street engine I would like somewhere around 425 at the crank. Thanks
Old 03-01-2013, 11:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you have a good sbc 400 block, that's what I would build.
A 400 bored 0.030" is a 406, bored 0.040" it's a 409, and bored 0.060 it measures about 413.
There are other ways to get different displacements. Using a 350 block bored 0.030" and a 400 stroke crank (3.75") gets you a sbc 383 stroker, which is a very popular combination. There are many other combos. But the basic rule is there's no replacement for displacement.
A displacement calculator is here if you want to play w/bore and strokes.
Longhand use: Bore X Bore X Stroke X .7854 X The number of cylinders = Engine Displacement.
Old 03-02-2013, 12:04 AM
vinniekq2's Avatar
what cylinder heads are you going to use for the street? 425 horses is not that much for a 400 but some heads do not flow enough...
Old 03-02-2013, 12:10 AM
vinniekq2's Avatar
street engine
choose the power you want,you have heads? ,do you know how many cfm they flow @.500?
Use a 750 cfm carb
a roller cam will make more power than the flat tappet
Old 03-02-2013, 10:46 AM
I have been thinking of a set of vortec I really ain't decided on it all yet I have been looking for a block and I Ain't thought of much else. The motor is in a gmc camper it has a 4 barrel carb. How is the chevy 302 and what hp could be got from it vs a 400. I heard the 400 has cooling problem
SBC 350 / SBC 383: Verification Tips and Methods lt1silverhawk Hotrodding Basics 8 06-17-2011 01:21 PM
305 sbc harmonic ballancer and a 350 sbc ballancer blackie350 Engine 2 02-17-2010 02:34 PM
SBC 377 vs SBC 383 70CHEVYSHORTY Engine 9 11-09-2009 12:18 PM
Old SBC to New OE SBC ROLLER LIFTERS??? juveteach Engine 2 04-27-2004 09:08 AM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 10:02 PM
