sbc high torque starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2010, 10:22 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
I posted this in electrical&didn't get much help,I recently put in a high torque starter&the other and I noticed when I would turn the car off the starter would go click click click...even when the cars not hot what could be causing this?
Old 03-16-2010, 09:15 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Kid,
Is this what your saying?
I recently put a high torque starter on my engine & the other day I noticed that when I turn the car off, & then try to restart it, the solenoid goes click, click, click, & the starter doesn't spin even if the engine isn't hot, what could be causing this?
Battery fully charged? clean battery connections, check & clean grounds, change the solenoid, check the brushes in the starter, have the starter checked at the auto parts store.
Rich
Old 03-16-2010, 09:50 AM
How fast is fast enough?
If everything else is fine, which I would presume if it worked until this point then it sounds like you have a bad starter. Could be a short too. What starter are you using?
Old 03-16-2010, 10:26 AM
Notlad1's Avatar
Don
Check your engine to chassis ground.
Don
Old 03-16-2010, 12:54 PM
two cups of tea
Wiki Edits: 2
Ill check everything before long&let you guys know,I broke a few toes so I'm kinda out of commision
Old 03-16-2010, 01:05 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
If the starter is clicking, as in trying to start, or something similar, you must be leaving out some details. Like how long does it keep doing this? I would take a test light, and check the terminals on the starter to see if any of them are getting juice when the shouldn't be. The only one that should be hot is the main terminal where the hot from the battery attaches.
400 sbc starter problems, Cracked Block. Adapter kit needed? tiresmoke55 Engine 7 04-16-2011 03:28 AM
SBC Starter and flywheel problems WakBordr7387 Engine 18 03-05-2011 02:13 AM
SBC starter problems punk1c5040 Engine 26 12-28-2008 07:58 AM
New High Torque Starter Connection prob . tony72 Engine 2 12-30-2007 06:24 AM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
