sbc horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2008, 07:33 PM
sbc horsepower
I'm starting to put together my sbc 350 and was wondering what kind of horsepower i should get ,it's a 350 40 over flat tops 9.5 comp. i had a set of 458642 heads done 202 160 some minor polishing 76cc , a lunati voodoo cam 213/219@50 .454 .468 lift 1.50 roller rockers a edelbrock duel plane air gap intake and a 650 demon carb , my buddys say it'll be a dog i'm just lookin for a strong running motor in my restored 71 c/10 thanks steve
Old 06-16-2008, 09:58 PM
Holder350's Avatar
Auto Parts Professional
Should be a strong motor....I'm not sure about the flow on the heads.
I'd say you would have a good solid 350hp....
Good luck on it....
Old 06-16-2008, 10:24 PM
Greg T's Avatar
www.krusinklassics.net
290 HP at best.
Old 06-16-2008, 10:43 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You might want to do some calculating on that compression ratio. Many flat top pistons rated at 9.5:1 compression are for 64 cc heads. A 76cc head will drop your compression a lot and you very well could end up with a low compression dog.
Old 06-16-2008, 11:08 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
This is what I came up with,
HP277@5250 TQ317@3750
Rich
I didn't add the .040 over, I'll do it again
HP282 @5000 TQ326@3500
Old 06-17-2008, 02:11 PM
Greg T's Avatar
Originally Posted by richard stewart 3rd
Hi,
Rich
As I said. 290 at best.
Old 06-17-2008, 02:21 PM
dh79's Avatar
280 is my estimate. Many people with a similar engine will say it's 350 hp; but they're wrong
81 Grand Prix, 355, 700r4, 8.5" 4.10
64 Oldsmobile Jetstar, all original
Old 06-17-2008, 03:16 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Its all in the heads. With 76cc's you're not getting a really efficient burn. I'd be a little skeptical about the compression too (lots of times they'll say 9.5:1 and that's not really what you end up with). Last, I think 2.02 valves are a little aggressive for the size cam you have, but they'll work.
The easiest thing you could do would be a head upgrade in the future. Personally I'd go with a 383 or 400, 9.5:1 compression (assuming iron heads) would be great about perfect.
I like your cam or something similar for a larger-cube smallblock truck motor. You'll get a good off-idle dig which would be really nice.
In any case, best of luck!
K
Old 06-17-2008, 03:35 PM
E.T. divided by $ spent= Speed
2.02s are a bit big for your cam but they'll work.As said.
The Goodwrench motor with the 216/228@050 Crane Powermax made 298Hp through closed 2 1/2" pipe. Thats 7.8:1 compression and 1.94s
Figure with 2.02s and a slightly smaller cam should average about the same but with less lowend due to your bigger valves.
The big valves and lower compression may suck a bit of lowend out but if you have a 3 series gear you should be OK.
As far as the heads they aren't the greatest but for a street driver they should be fine IMO...Acording to the rest of the world though,nobody ever made 300Hp out of a SBC till the creation of aftermarket heads and credit cards BS.
Old 06-17-2008, 03:38 PM
I didn't see headers on your list of parts. You need them to make power. Small tube would be best.
That cam is too big if you are running a stock converter and a 3.08 gear. I would drop about 8 degrees of duration if you have a 3.08 gear (typical 71 c10 gear). Trucks are heavy so you need to use a little less cam than a car with the same engine and gears.
However, that cam would run ok with a 3.42-3.55 gear and a 2000 stall. Should run much better than a stock 71 350 truck engine (185hp).
Old 06-17-2008, 05:00 PM
thanks
thanks everyone to answer a few of the answers, i have a 700r 4 with overdrive tranny 3.73 rears and i've been thinking of aluminum heads but a little short on cash and credit right now, for some reason my woman had to have heat and a/c instead of a nice 383 stroker ,so i'm doing what i can to get back into the hot rod game. it's been about 15 years since i've been able to afford and have time to do this thanks all . steve
p.s. i thought headers were a givin...
Old 06-17-2008, 05:36 PM
I think it will run just fine. With a 3.73 gear and that ultra low first gear in the 700r, it should be able to get out of it's own way without any problems.
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 08:29 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 10:43 AM
???the 411 on HP now & then ??? Rob Keller General Rodding Tech 20 07-13-2005 07:00 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 11:12 PM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 04:44 PM
