sbc horsepower? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2011, 03:53 PM
sbc horsepower?
I have a 350 .40 over with flat tops stock 1.94 heads. Cam lift is .443 int .465 exh has performer rpm intake with600 carb. Also has set of headers. Any idea on crank horsepower?
Old 10-29-2011, 05:00 PM
342.7 at 5600rpm
Old 10-29-2011, 09:52 PM
260 HP at 5200 RPM
Old 10-29-2011, 11:37 PM
327NUT's Avatar
As you can tell by the first 2 replys which were obviously joking around, with the little amount of info given on your combo there's really no answer.
Old 10-30-2011, 12:01 AM
All stock but crank has been turned and balanced,I would like to think the comp ratio is around9:5:1. Any honest answers would be great.
Old 10-30-2011, 01:38 AM
There is no way anyone can guess with any accuracy, you are not supplying enough information.
What heads?(casting number) What CC's are the cambers? What type of valve job?
What short block?
Why do you think its 9.5:1
Whats the durration of the cam
What head gaskets are you using?
Whats the piston to block surface at TDC?
Diameter and length of headers?
Rocker ratio.
Was the cam degreed during installation, how is it installed?(straight up, advanced, retarded?)
What type of ignition, whats the timing?
383 horsepower lukeembry Engine 1 03-02-2009 05:59 AM
horsepower!!!!! mighty whitey 48 Introduce Yourself 1 02-14-2009 09:13 PM
Horsepower... jamesm Introduce Yourself 2 08-30-2004 08:43 AM
horsepower? cadillac man Hotrodding Basics 3 08-13-2004 04:35 PM
Horsepower.... and horsepower loss PonchoTA79400 Engine 3 03-13-2004 10:25 AM
