SBC - How high or low should it be? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2012, 11:22 PM
31fordcoupe's Avatar
Last journal entry: Gunked up 454 water jacket
Hello gents. We are at the time when we are starting to mach up my 327 in my 31 Coupe. My question is this; how high or low should the engine be in relation to the frame rails? I have attached several pics of the mach up and the engine appears to me to sit to high.
When looking at it from the side the oil pan protrudes only about 1" below the bottom of the frame rail which doesn't look right to me either. The measurement on each side from the inside top edge of the frame rail to the bottom of the engine mount is 5.25" (again seems kinda far). We are thinking about lower the engine about 1.5-2", but I wanted to hear from all of you here first before doing so.
Our pinion angle looks pretty good. Right now the carbs are at about a 2 degree down angle from front to rear and we anticipate that the carbs will be right at level once the weight of the engine and tranny is on the frame. But after running a string from the tranny tail shaft to the pinon on the 9 inch, with a two inch lower height than what we have right now, it looks better.
I also assume that the lower the engine is, the better my center of gravity will be.
I also wanted to mention that my pinion is not "centered" in the axle housing. The rear end has been narrowed but an equal amount of axle housing was taken off each end on my 9" so my driveline does not go straight down the center of the vehicle (instead is it is off to one side when looking at it from front to rear). Is this going to be a big problem for pinion tail shaft alignment? I have read over several of the postings here on pinion angle and just want to get clarification.
Here are some pics for reference...Thanks.
Side shot of the Coupe.
Front shot of the Coupe.
Wide view of engine mach up.
Frame rail side view showing relative position of the bottom of the oil pan at current engine height.
Passenger side view of proposed height of engine. Bottom of engine mount to inside corner of frame rail is 5.25".
Drivers side shot of engine with tape measure for reference.
Old 01-24-2012, 12:38 AM
327NUT's Avatar
Totally up to you and the look you want but I think it's way too high, almost 60' gasser style....but again, if thats how you want it. Here are some pics of my earlier 331" chevy in my TCI chassis, the bottom of the pan was right ar 6" off the deck. Then I've added a few pics of the 507" Cadillac in the same chassis and how I did the mounts, same distance on the pan. You may want to put the distributor in so you can gauge how much room you need from the firewall in case you ever have to pull it. It's just a hit and miss deal until you get it the way it fit's best.
Old 01-24-2012, 01:14 AM
327NUT's Avatar
Sorry, the web page wouldn't let me upload the pics, I'll try again. Hey it worked....anyway kind of hard to see but the chevy motor mount was just about even with the top of the chassis...maybe an inch higher.
ID:	62177   Click image for larger version
ID:	62178   Click image for larger version
Old 01-24-2012, 04:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I like the height of it as-is. If you want to see more oil pan below the frame rails get a deep sump on there.
If you're going to use aluminum heads the c/g won't be effected as much. The water pump is centered on the radiator shell which is a consideration if you're using a mechanical fan. The gassers did that to improve traction/weight transfer. They went a LOT higher than you are; your car just gives the hint of a gasser- a look I personally dig.
Old 01-24-2012, 07:43 AM
Last journal entry: update
Way too high, especially at the front, way too far forward. If the chassis is gonna ride nose-down, then the engine doesn't have to sit parallel with the road.
Old 01-24-2012, 08:18 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
back as far as you can (doesnt look like you can get a lot more)
and a couple inches lower for sure (which will give you more backward clearance space)
looks like its sitting or leaning a lot to the left in the pics, also
Old 01-24-2012, 09:06 AM
Banned User
Personally i would get it as close in line with the pinion as possible as far as height.
As far as left/right, if the pinion is actually offset more to the right (passenger side) then great because you could actually put the engine slightly more to the right and this would comphensate for the weight difference of the driver sitting on the left---assuming you will drive it alone at least part of the time? Thus, this would give more equal weight distribution.
NOTE: that the suggestions are coming from someone who is not an engineer---it's just what i would do if i were in this situation.
Can i ask about your front suspension?
Old 01-24-2012, 02:42 PM
327NUT's Avatar
I didn't comment on the front end....but I have to say, I hope you're running fenders on the car but it doesn't look like you will be. A fenderless car or high boy as it's called really needs a traditional dropped axle front end. The stock or even aftermarket IFS just looks too bulky and out of place.....but again, to each his own and the budget he has to work with.
I also don't think the engine is too far forward, once you add the water pump and fan it should be just fine...besides it looks like it's back as far as it can go right now. Model A's aren't known for their generous engine compartment.
Old 01-24-2012, 04:18 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
As long as your intake sets level front to rear and side to side Where your carbs set! at the cars ride height you like! you would want the gas in your bowls setting pretty level (your oil too) + or - a couple of degrees. Put it where you want It: and you dont have to compensate for your weight Unless your really hefty and then youd have to make your doors bigger I like it at that height !! What ever floats your boat
Jester
Old 01-24-2012, 04:26 PM
If it appears to you to be too high , then it's too high . FWIW Too high for me too !
Old 01-24-2012, 04:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
FWIW Holley sells wedge plates to adjust the angle so the carbs are level:
p/n 717-1 7 wedge with square bore flange
p/n 717-2 12 wedge with square bore flange
Aluminum, includes gaskets, studs & nuts.
Old 01-24-2012, 04:51 PM
406 bug's Avatar
9.82 @ 139mph
Before settling on the height I would mock-up head, headers, steering and whatever else that could become a future clearance issue.
Old 01-24-2012, 09:15 PM
Thanks Cobalt I forgot to mention wedges ( I didn't know who made em anyway
Chris
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 02:22 PM
Total timing, high CR, High altitude, street car. Biscuit6447 Engine 5 08-06-2009 07:30 PM
Do I have a high volume or high pressure oil pump ? y2k600f4 Engine 6 12-16-2008 07:12 PM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
high volume or high pressure pump? bullheimer Engine 3 05-09-2004 05:19 PM
