Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC HVP oil pump, low pressure
Old 01-09-2009, 02:37 PM
red65mustang red65mustang is offline
"where" is the sender reading psi on the oil galleys does change the readings....
sounds like your reading the psi after the mains "and" cam bearings leakage PSI loss....
if it is only 15-20 at say 3000rpm, there is a problem
