sbc id needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2012, 08:55 PM
sbc id needed
the set of numbers i have are K1126CTL 12E561211
the numbers on the heads are 3927186
trying to figure out what i have thank you for any help
Old 11-11-2012, 09:04 PM
RWENUTS's Avatar
Chevy VIN, Trim Tag and Drivetrain Information & Decoding
Old 11-11-2012, 09:32 PM
Smarter than i look
Last wiki edit: Upgrading to HEI
Wiki Edits: 2
"K" Generally in the vin stamp, denotes a truck engine. Only that it was assembled to go into a truck, not that it is a specifically truck engine.
The 186 cylinder heads are Z28 style heads, used on 302s 327s, and depending on who you ask, LT1 350s. Closed chamber 202/160s with acessory bolt holes.
Old 11-11-2012, 10:53 PM
DoubleVision's Avatar
CTL 70 350 Corvette 300 ZQ-3 4-spd 4-Brl
CTL 72 350 Nova 165 L-65 TH 350 2-Brl
CTL 72 350 Chevelle 165 L-65 TH 350 2-Brl
CTL 72 350 Camaro 165 L-65 TH 350 2-Brl
CTL 75 400 Impala 175 LT-4 T-H 400 4-Brl
CTL 76 400 Impala 175 LT-4 T-H 400 4-Brl
CTL 78 305 Impala 145 LG-3 TH 350 2-Brl
The "K" in this case stands for:
K St. Catherines, Ontario
The 186 castings are "camel hump" heads by the 2 humps casted on the front and rear of the head. These came on mid level to high performance engines in the late 60's and early 70's.
On intermediate performance engines they came with 1.94 1.50 inch valves and 64cc chambers. On high performance engines they came with 2.02 1.60 inch valves with 64cc chambers. If the heads are factory to the block it's possible they came on the first engine in the suffix code above which is a 300 horsepower 350. If not then someone has simply purchased them and added them to the engine you have which is rather common.
If you want to know what engine you have exactly you'll need the casting number of the block which is on the drivers side bellhousing flange.
Old 11-11-2012, 11:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Next time, use this to decipher the codes.
The suffix CTL was used numerous times:
The 2 in the second position of the partial VIN makes this a '72 engine, so from the list above you see the choices.
There is a cast in number (not stamped) back by the distributor that will be the casting number. Other side from it should be a date code. Look at link for details on the casting number and date code. Use them to verify what you see above.
Sbc V-belt Help Needed gmc1990rodder Engine 92 09-20-2016 01:41 PM
SBC cam ID help needed v8hed Engine 4 03-14-2010 05:39 PM
sbc oil consumption help needed jw4413nv Engine 5 05-13-2007 01:41 PM
SBC cam bearing help needed flyin99 Engine 2 04-07-2007 09:46 PM
sbc in a 53 stude info needed studego Introduce Yourself 2 12-07-2004 07:04 PM
