SBC idle problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2005, 11:45 AM
97Z28's Avatar
NTI Grad.
SBC idle problems
i have an 83 chevy with a 350. and a 4bbl holley carb. the problem is this... it'll start and sometimes it'll run for a little bit before it dies, and other times it'll start and die right away. it has a brand new mechanical fuel pump on it, so its getting gas to the carb. i've tried changeing the mixture on it and it still does the same thing. and when it does run and i hit the gas it dies or stumbles. does anybody have any ideas?? thanks in advance.
Old 08-16-2005, 12:06 PM
spinn's Avatar
yea, how is the choke set?
there is a cold idle screw , try dicking with that.
now, if it doesnt run at all, when was the last time you rebuilt the carb? it may just need a cleaning. then you can set everthing to base, and start your tunning over.
Old 08-16-2005, 12:12 PM
97Z28's Avatar
NTI Grad.
do you know right off hand where the cold idle screw is? and how do you set the choke. sorry im so stupid... but im not used to carbs.
Old 08-16-2005, 12:15 PM
spinn's Avatar
stupid? just cause your not familiar with a holley carb? nahh im not like that ,my edges are round.
the cold idle screw is on the underside of choke, what carb do you have? whats the # on the choke tower?
Old 08-16-2005, 12:23 PM
97Z28's Avatar
NTI Grad.
the top number is 1850-5... i think and the bottom number looks like 1180... its hard to tell. i probably need to pull the carb and clean it
Old 08-16-2005, 12:28 PM
spinn's Avatar
will it run above idle?
do you have the secondaries set ? like little boxes? or closed?
there is a screw at the base plate underneath?
one more, when itdies does it still squirt fuel from the accelerator pump?
Old 08-16-2005, 12:37 PM
97Z28's Avatar
NTI Grad.
no... it wont run above idle... doesnt matter if i hit the gas or not... it just dies. the cold idle screw is set to almost full open... tried backing it off... still the same thing,
i have no clue about the secondaries
yeah...i checked to see if there was still fuel in the carb... theres plenty in there when it dies
Old 08-16-2005, 12:55 PM
spinn's Avatar
im still thinking its your carb setup the secondary blade function is critical to starting. maybe return to base line carb settings. idle screws 1.5 truns out. ......
man youknow what? when im stumped and suspecting the fuel system, after i got blue spark, (also even with crappy compression it will still run but like crap,) i disable everything i can. back off the accelerator pump. disable the choke cause you can choke it yourself. set the throttle blades on the underneath. this also makes you seal and tightnen the carb down good when you put it back on. its just my method of madness.
you cant sit back and look at it from the outside. get familiar with that bad boy.
Old 08-16-2005, 01:00 PM
97Z28's Avatar
NTI Grad.
im thinkin its the carb setup too. the thing is pretty cruddy. i think im just gonna tear it down and clean it up. return everything to baseline and go from there. i really appreciate you taking the time to help me with this. thanks.
SBC tunnel ram w/2x450 holleys problems rodnok1 Engine 7 10-12-2010 03:54 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
new edelbrock won't idle... Trav Engine 1 11-29-2003 08:22 PM
SBC idle problems need help zukgod Engine 2 06-10-2003 11:17 PM
SBC, starter,flex-plate problems agasmantwo Engine 4 12-17-2001 10:59 PM
