Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC ignition problem
Old 10-26-2012, 06:01 PM
EOD Guy's Avatar
EOD Guy EOD Guy is online now
run a temp jumper from the pos post on the battery to the + terminal on the HEI...... try and crank it up, if it starts and runs you've got a wiring problem from the switch......
YOU WILL HAVE TO PULL THE JUMPER to kill the motor if it starts!
