Originally Posted by Hammerstein
When I said its grounded on the choke's ground, I was referring to a Summit aftermarket carb that has a 3-4 inch wire coming from the choke housing to another screw on the carb (grounding it to the manifold, cylinder heads, ect) I ran a wire from the center pin on the HEI (the ground) and ran it to that same screw to ground the coil, but its not appearing to be working. I then grounded it to the terminal on the alternator to be sure my ground was good, but had no luck. Everything says its a bad ground, but I can't figure out how it could be bad.
OK, I understand.
Try connecting the 3-wire female pigtail coming from the distributor to the male connectors under the coil cover instead of running the ground separately. Be sure there are all three male connectors, and that they're also connected to the BATT and TACH positions of the coil cover.
If you have a tach attached to the TACH terminal, try removing the tach.
