Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc inneed of medical attention 911
Old 03-14-2013, 06:40 AM
engineczar's Avatar
engineczar engineczar is offline
Cobalt is right on point with this. With all the plugs removed from the oil passages (including the one under the rear main cap) it's something you can do yourself. If you're going to brush hone the bores now is the time before you wash it. Using hotter water will slow down any rusting until you can get it dried off and WD40'd. Then once you've done all this install the cam bearings and oil plugs.
BSE Racing Engines
The Following User Says Thank You to engineczar For This Useful Post:
sweetlil66 (03-14-2013)
