Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc inneed of medical attention 911
  #90 (permalink)
Old 05-10-2013, 09:06 PM
sweetlil66's Avatar
sweetlil66 sweetlil66 is offline
Originally Posted by cobalt327 View Post
You can remove the rotators, this is commonly done. Remember to check the valve spring installed height. This is important because some heads had different depth spring pockets and others used shorter exhaust springs to compensate for the rotators. In the end, you want the springs all installed to their specified installed height so the spring pressures are correct for the cam you're using.
As for the seals, if you are NOT using positive type oil seals on the valve stems, reuse the tin shields and O-ring like the factory used for many years.
If you remove the tin shields and only use the O-rings the valve guides will pass more oil than is necessary. That can hurt performance by contaminating the incoming air/fuel mixture w/oil and can allow carbon to build up on the back sides of the valves, hurting flow. And the engine may smoke.
If you remove the tin shields AND do not use the O-rings, the engine WILL smoke.
Valve spring installed height
Valve train points to check
Valve train geometry
Thanks colbt. The first link isnt working but iv been looking around and found the fallowing info. Is this rihgt?
Valve Spring Tech
Valve Spring Pocket Clearance
Valve spring pocket clearance is the gap between the inside diameter of the valve spring pocket (or cup, if used) and the outside diameter of the valve spring.
Too much clearance will result in the spring "dancing" around in the head, which "beats up" the spring mounting surface and the spring itself. If this is the case, a spring cup may be used. Additional machining of the spring pocket may be required to accept the spring cup.
Not enough clearance will bind the spring in the pocket, overstressing the bottom coil by limiting its movement and not allowing the spring to "grow". This will cause the bottom coil to wear against the head and/or prematurely fail. Machine the valve pocket using a Spring Seat Cutter if not enough clearance exists.
Valve Spring Retainer Fit
The valve spring retainer should fit the valve spring being used. A slightly snug fit is acceptable, however a fit that is too tight can overstress the top coil, and cause it to fail. A fit that is too loose can lead to spring "dancing."
Valve Spring Installed Height
The installed height of the valve spring is the distance between the valve pocket (or cup, or shims) and the outer edge of the spring retainer (which is the height of the valve spring) when the valve is closed. To check installed height, follow the following procedure:
Install the valve in the guide.
Install the retainer and valve locks.
Install all spring cups and/or valve spring shims (basically, everything except the valve spring).
Hold the valve closed by pulling the retainer up tightly against the valve locks.
Measure the distance between the outside edge of the valve spring retainer and the spring seat. A snap gage or a height micrometer should be used.
Check the distance against what is recommended on the camshaft specification card. An installed height of +/- 0.020" is acceptable.
If the installed height is not within 0.020", either machining of the valve pocket, or removal/installation of valve spring shims is necessary.
Repeat this procedure for the rest of the valves.
Valve Spring Retainer to Valve Seal Clearance
The distance between the innermost step on the valve spring retainer and the valve guide must be 0.090" larger than the maximum valve lift of the camshaft. Measure the distance between the top of the valve seal to the bottom of the valve spring retainer. After adding 0.090" to your measurement, it should still be larger than the maximum valve lift of the camshaft. If not, machining of the valve guide in necessary for adequate clearance.
Valve Spring Coil Clearance
Coil clearance is the distance between the valve spring coils when the valve is it maximum lift (fully open). A minimum of 0.060" must exist between the coils at maximum lift. Coil bind is when the valve spring is compressed fully-to the point that all of the coils are "stacked up" on top of each other. For high RPM applications, .100" is recommended . Coil bind is a catastrophic condition that will result in valve train failure. Disassemble each spring (if multiple springs are employed at each valve). Check all the springs (both inner, and outer springs) If there is not 0.060" - 0.100" minimum of clearance between the coils, the solutions are: the valve retainer, the valve locks, the valve, or the spring must be changed; the spring pocket must be machined. Keep in mind that these modifications will change the valve spring installed height
Valve Spring Retainer to Rocker Arm Clearance
When installing the rocker arms, check to see that the inside of the rocker arms clear the spring retainers. Many rocker arms have a "relief" to accommodate large valve spring retainers.
Valve Spring Run-In
Each set of Lunati valve springs are hand-selected to keep load variations below +/- 10% of the next. However, it is important to "run in" your new valve springs at low RPM using the following procedure:
Start the engine and run the engine between 1500 and 2000 RPM until the engine reaches operating temperature.
Shut off the engine and allow the springs to cool.
After initial run-in, most springs will lose a slight amount of pressure. Re-check and shim up the valve springs if necessary. After the springs are "run in", spring pressure should remain constant until the point of replacement.
