sbc inneed of medical attention 911 - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 05-03-2013, 02:13 PM
bigdog7373's Avatar
Of course it's fast
He should warranty the work he did. If he put the engine together knowing there is a problem then he better take it back apart and fix it instead of giving you some bs that he's not warrantying it.
On another note, if he honed it there shouldn't be any rust in the cylinders. There shouldn't be any rust anywhere inside the motor.
The Following User Says Thank You to bigdog7373 For This Useful Post:
sweetlil66 (05-03-2013)
  #77 (permalink)
Old 05-03-2013, 05:01 PM
sweetlil66's Avatar
Thanks big dog. Im going to call him and speak with him right now.
  #78 (permalink)
Old 05-03-2013, 06:12 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Hold on for a minute.I am thinking he sensed you not wanting to spend for new pistons and tried the standard rebuilder's move of hone and go.Then found not CRUSTY RUST,but rust pits.So moving forward towards a bore,have it sonic checked before you pull the trigger on that.If that machine shop can't do that kind of work or can't hone with torque plates,find someone who can and return the parts you can no longer use.
The Following User Says Thank You to 1Gary For This Useful Post:
sweetlil66 (05-04-2013)
  #79 (permalink)
Old 05-03-2013, 07:24 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by sweetlil66 View Post
Update.
I went ahead a fallowed yalls advice and had the shop do all the work.
The crank did end up needing to be turned - The mains wear bad but the rods wear not to bad.
We found 3 rods and or pistons that wear backwards.
I got a new ring/bearing gasket set.
I got the vating done.
Everything was worked on and or cleaned except for having the cylinders bored and new pistons.
Now heres what threw me for one.
I had him assemble the lower end for me because i was lacking some tools - with the new parts and labor it was 600$.
I told the shop own upon dropping the engine off- If the walls wear in spec and it wold run happy as is do not bore just hone.
Yesterday when i get there to fill out paper work and such. he tells me he wasnt going to warranty the engine because the rust that WAS in the one of the cylinders - Since he did not bore it and just hone it he did know how long the engine should last. He was saying rust can cause some crazy stuff to happen.
I kinda wish he would have called me and told me this before hand..One would think by me saying IF EVERYTHING WAS IN SPEC this would mean any thing that could effect life of the engine and or warranty.. It sounds like to me he is saying it may only last a few thousand miles. What did I pay for?
Like I said last time I checked compression the engine had 135 across all cylinders so I assume there not to much wrong with the walls.
He honed the engine - I can see the crosscutting in the walls. Some of the cylinders had a light ring at the top and others have a more noticeable ring around the top.....
So everything is new expt pistons and the walls being bore.
He said with the cam I used - I needed to change valve springs over to a bigger set. Something to do with the exhaust valve wiping out the lobs of the cam? He sold me a set for both heads - exhaust and intake for 30$. He said Ill remove a shim at the top of the spring and re-use valve keeper.
He said as far as my break in goes - I should use Valvoline Vr1 racing oil - MAKE SURE IT HAS ZINC.
He told me to run 20 min at @2k then change the oil filter - then drive 500 miles and do a oil change again. Altho He said this Im really leaning to Grays - joe Gibbs racing oil for break-in oil for the break in and then changing to oil to http://www.summitracing.com/parts/jgr-02006
Anyway. If yall got any idea on the above please post.
I got the short block and putting it together soon.
Try not to keep a constant 2000,vary it a little 1800-2300 ,when you reve it then back off it helps wash down the cylinder wall to seat rings faster, after break in the walls will retain oil in the rings around piston and in hone marks ,so after break in it does not matter about rpm then ,GOOD ADVICE USE ZINC but Vavoline RACING oil does not contain ash ,it is for cars with Roller cams ,Not my first choice
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
  #80 (permalink)
Old 05-04-2013, 12:33 AM
sweetlil66's Avatar
Not quite understanding. He did say I should get some good miles out of it but wasnt sure. After speaking with him today. He did say he would warranty the lower end but not the cylinder and or say how much compression I should Have. He said only one cylinder had enf rust to really worrie about.
He did fix alote of stuff.
A few of his guys said that if I use good oil and I had the 130 compression I claimed from before the rebuild It should be no problem to get 100k.
The short block is together ext for pan gasket and oil pump. What do you mean have parts returned gray? Thanks all.
  #81 (permalink)
Old 05-04-2013, 07:51 AM
1Gary's Avatar
Well what I am saying is this,from what your saying,is a new game in that now you have perfectly round rings<unlike before worn to whatever the bore was in that one cylinder>trying to seal against a nu-smooth bore surface.So your compression from before really doesn't come into play anymore.He's saying this because of the fact,sounds like,he can't be sure how that cylinder will ever seal correctly,nor now what your compression will be now or for the long term.That is a gamble now.
No doubt about it,guys are forced to do clean up oversized bores for situations just like yours.And that reinforces the need for sonic checks to see wall thickness so the machinist knows how much a block can be safely over-bored. If it is enough for him saying he won't stand behind the one bore,than it is enough for you to be concerned about it.
You have been through hell with this not even knowing if it could be saved.Now is not the time to make what could be a risk bad decision and not have the insurance of standing behind a rebuild with your wallet to buy new pistons for the over-bore and that rings to go with it.Returning the rings you have now which wouldn't work on a different bore size.
BTW as the saying goes:
Without detailed pictures of the bore in question,all we can do is form a opinion from what your telling us.
sweetlil66 (05-05-2013)
  #82 (permalink)
Old 05-05-2013, 01:49 AM
sweetlil66's Avatar
He did say the cylinders wear with in spec of 030. over stock bore and said I could easily get to 060. with no issues.. *** He claimed that I should get alote of miles out of it***
He claims that it appears to him that some one had rebuilt the engine and used cheap parts and installed the pistons wrong. He believe someone did not use the proper oils for or after breakin and it killed the cam and took everything else with it. He did not think from looking at the cylinder walls that many miles had been turned. He aslo said any engine that he works on that has had any kinda rust in it he does not warranty unless bored.
He also noted - The crack mains wear bad and rods wear almost perfect spec.
He said someone could have ran it out time to far and that could cause the mains to take a beating.
We know that rust from that cylinder was form a cracked head.
After speaking with him today he claimed to support the lower end if it has any issues.
Im done here. This is going to have to work or im getting ride of the thing. I can not do this with a disabled wife and 1 kid and anther on the way with no job.
Im sure if there was a major problem he would have not done the work. He just comes of that kinda guy to me. He was so picky about his work he woulden install my timing cover because it was dirty (He said if I wanted it installed - I would have to have it vatted- He vatted it for free (30 min wait) He installed it and sent me on my way.
  #83 (permalink)
Old 05-05-2013, 02:48 AM
lhmurphy's Avatar
I hope you get that thing back to running! But when you do the rebuild ask your machinist about putting one single tiny groove in each lifter bore to help oil your cam. The grooves are cut differently on the driver and passenger side lifter bores (If it's a hydraulic flat tappet) If he has the tool it would be a little more insurance that a machinist should do for free if he is working on your block. Good Luck! Hope you get it done!
The Following User Says Thank You to lhmurphy For This Useful Post:
  #84 (permalink)
Old 05-07-2013, 01:37 AM
sweetlil66's Avatar
When I started this whole bizz I installed a new oil pump (This is before I knew the issues)
It was a high vol oil pump. Im wondering if I should reuse it or not. Pretty much all new oil was ran threw it but I worry about grit from the flat cam possibly hurting the pump or being inside the pump its self.... If i reuse I plain to PRIM the pump a few mins cycling any junk inside . The pump its self did not see more then a 1 or less of run time. What should I do?
Also Is it possible to install or change valve springs with the heads on?
The shop guy solid me bigger/stronger valve springs and told me to remove this upside down blow washer looking thing (Not sure what he called it) - I just ordered a valve spring compressor and wont see it for almost a weak - I dont want the heads of that long because the engine is in the house (Living room) and I have kids. We all know the saying (SOME PEOPLES KIDS) That saying was ment for my kids lol.
  #85 (permalink)
Old 05-07-2013, 02:23 AM
sweetlil66's Avatar
Im not sure what to do here.
The head on the truck had.
Valve shim - spring - A bowl that sets down on the valve about a 1ich or so -Valve lock/keeper
Now the exhaust valves is the only differences between the the head I got new and the head on my truck. The exhaust had shim- valve spring - cup that covers 1ich of the spring (Kinda looks like it to protect the spring or something) - Valve spring cup(Looks like this VALVE SPRING CUPS, USE WITH STOCK OD SBC SPRINGS ON AFTERMARKET HEADS - Alex's Parts Sales) - valve spring RETAINER.
new head -Shim - Spring - bowl - cup - RETAINER (only on )
Other head- Shim - Spring - bowl - RETAINER - Ill try to upload a pic.
  #86 (permalink)
Old 05-07-2013, 11:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The tin shield you're describing is an oil shield (below). It, along w/a small rubber O-ring, was Chevy's way of controlling the amount of oil reaching the valve stem. This was used into the '80s.
The shields can be done away with if the seal is changed to a positive-type seal instead of the shield and O-ring setup. Otherwise, reuse them along w/new O-rings.
You need to see if the exhaust valves have rotators on them (left valve below, right valve has regular retainer). Rotators are a type of retainer that allows the exhaust valve to turn as the engine runs to lessen wear. They are thicker than the retainers found on intake valves, and are not generally used in performance applications.
The springs can be changed w/the heads on the engine. This is done w/compressed air to keep the valves closed or by filling the cylinder w/thin rope or cord until it's full, then the crank is rotated to push the piston against the rope to hold the valves closed. This is done on each cylinder on the compression stroke. We can add details if you need them.
The spring compressor has to be the type that works on a head assembled to the block. Some compressors can only be used w/the head off the engine as I'm sure you know.
The Following User Says Thank You to cobalt327 For This Useful Post:
sweetlil66 (05-08-2013)
  #87 (permalink)
Old 05-07-2013, 11:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A diagram naming the components. The stock tin oil shield rotator type exhaust retainer isn't shown:
Below the tin oil shield is #9, the small O-ring is #8. The retainer is #5, can be a rotator type retainer on exhaust valves on some heads as I mentioned earlier. The head below is from a Chevy V6 but is the same as the V8 minus a cylinder:
  #88 (permalink)
Old 05-08-2013, 02:32 AM
sweetlil66's Avatar
Well your my new BFF!
He wants me to remove the rotators.
The pic you posted with the rotators on the left and non-rotators on the right is the way the new head is set up.
The head that was on the truck - Has rotators removed. So did the junk head.
QUOTE- The shields can be done away with if the seal is changed to a positive-type seal instead of the shield and O-ring setup. Otherwise, reuse them along w/new O-rings.
Do I need to do away with them? Im screed to death im gonna kill the cam on break in - Iv been reading horror story's!
I did speak with him to day and he said I need to remove the -Rotators (Use the spring& Retainers I got and make the exhaust valve look like the intake.
He built the head so Im guessing he knows what he is talking about.
  #89 (permalink)
Old 05-08-2013, 06:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can remove the rotators, this is commonly done. Remember to check the valve spring installed height. This is important because some heads had different depth spring pockets and others used shorter exhaust springs to compensate for the rotators. In the end, you want the springs all installed to their specified installed height so the spring pressures are correct for the cam you're using.
As for the seals, if you are NOT using positive type oil seals on the valve stems, reuse the tin shields and O-ring like the factory used for many years.
If you remove the tin shields and only use the O-rings the valve guides will pass more oil than is necessary. That can hurt performance by contaminating the incoming air/fuel mixture w/oil and can allow carbon to build up on the back sides of the valves, hurting flow. And the engine may smoke.
If you remove the tin shields AND do not use the O-rings, the engine WILL smoke.
Info:
Valve spring installed height
Valve train points to check
Valve train geometry
sweetlil66 (05-10-2013)
  #90 (permalink)
Old 05-10-2013, 09:06 PM
sweetlil66's Avatar
Info:
Thanks colbt. The first link isnt working but iv been looking around and found the fallowing info. Is this rihgt?
Valve Spring Tech
Valve Spring Pocket Clearance
Valve spring pocket clearance is the gap between the inside diameter of the valve spring pocket (or cup, if used) and the outside diameter of the valve spring.
Too much clearance will result in the spring "dancing" around in the head, which "beats up" the spring mounting surface and the spring itself. If this is the case, a spring cup may be used. Additional machining of the spring pocket may be required to accept the spring cup.
Not enough clearance will bind the spring in the pocket, overstressing the bottom coil by limiting its movement and not allowing the spring to "grow". This will cause the bottom coil to wear against the head and/or prematurely fail. Machine the valve pocket using a Spring Seat Cutter if not enough clearance exists.
Valve Spring Retainer Fit
The valve spring retainer should fit the valve spring being used. A slightly snug fit is acceptable, however a fit that is too tight can overstress the top coil, and cause it to fail. A fit that is too loose can lead to spring "dancing."
Valve Spring Installed Height
The installed height of the valve spring is the distance between the valve pocket (or cup, or shims) and the outer edge of the spring retainer (which is the height of the valve spring) when the valve is closed. To check installed height, follow the following procedure:
Install the valve in the guide.
Install the retainer and valve locks.
Install all spring cups and/or valve spring shims (basically, everything except the valve spring).
Hold the valve closed by pulling the retainer up tightly against the valve locks.
Measure the distance between the outside edge of the valve spring retainer and the spring seat. A snap gage or a height micrometer should be used.
Check the distance against what is recommended on the camshaft specification card. An installed height of +/- 0.020" is acceptable.
If the installed height is not within 0.020", either machining of the valve pocket, or removal/installation of valve spring shims is necessary.
Repeat this procedure for the rest of the valves.
Valve Spring Retainer to Valve Seal Clearance
The distance between the innermost step on the valve spring retainer and the valve guide must be 0.090" larger than the maximum valve lift of the camshaft. Measure the distance between the top of the valve seal to the bottom of the valve spring retainer. After adding 0.090" to your measurement, it should still be larger than the maximum valve lift of the camshaft. If not, machining of the valve guide in necessary for adequate clearance.
Valve Spring Coil Clearance
Coil clearance is the distance between the valve spring coils when the valve is it maximum lift (fully open). A minimum of 0.060" must exist between the coils at maximum lift. Coil bind is when the valve spring is compressed fully-to the point that all of the coils are "stacked up" on top of each other. For high RPM applications, .100" is recommended . Coil bind is a catastrophic condition that will result in valve train failure. Disassemble each spring (if multiple springs are employed at each valve). Check all the springs (both inner, and outer springs) If there is not 0.060" - 0.100" minimum of clearance between the coils, the solutions are: the valve retainer, the valve locks, the valve, or the spring must be changed; the spring pocket must be machined. Keep in mind that these modifications will change the valve spring installed height
Valve Spring Retainer to Rocker Arm Clearance
When installing the rocker arms, check to see that the inside of the rocker arms clear the spring retainers. Many rocker arms have a "relief" to accommodate large valve spring retainers.
Valve Spring Run-In
Each set of Lunati valve springs are hand-selected to keep load variations below +/- 10% of the next. However, it is important to "run in" your new valve springs at low RPM using the following procedure:
Start the engine and run the engine between 1500 and 2000 RPM until the engine reaches operating temperature.
Shut off the engine and allow the springs to cool.
After initial run-in, most springs will lose a slight amount of pressure. Re-check and shim up the valve springs if necessary. After the springs are "run in", spring pressure should remain constant until the point of replacement.
medical nos BLZR81 Engine 4 01-23-2010 07:32 AM
Medical Oxygen Regulators ? kdc49 Garage - Tools 21 04-04-2006 10:52 PM
What are your medical conditions? lluciano77 Hotrodders' Lounge 62 12-01-2004 12:03 PM
medical question 40fordtruck_son Hotrodders' Lounge 28 10-17-2004 02:18 PM
New Medical Breakthrough Kevin45 Hotrodders' Lounge 8 06-23-2004 11:09 PM
